58 dynamic 88 auto
Old Nov 8, 2020 | 04:12 PM
Brownie12's Avatar
58 dynamic 88 auto
Hi there
trying to find a vibration in our 4 door sedan , I have not taken driveshaft off yet , was not put together on my shift
coupla questions::
does the slip joint have a master spline or can you rotate it
to any spline position as the UJ yokes are not in phase
are they meant to be in phase?
thanks
NZ Brownie
Old Nov 8, 2020 | 04:25 PM
I’m not familiar with the transmission in a 56, but I have never seen a slip yoke with a master spline. I suppose anything is possible.
If the yoke bolts on, mark the flanges to ensure it goes back together the same way it came apart. If the yoke will go together multiple ways, you can try to clock the yoke/flange in different positions to possibly tune out the vibration. That’s assuming the joints are tight without excessive slop.
Old Nov 8, 2020 | 05:38 PM
Charlie Jones's Avatar
Phantom Phixer
Yes , the u-joints need to be in phase .
And yes , joints that are out of phase can cause vibration .
Old Nov 9, 2020 | 12:08 PM
Brownie12's Avatar
Thanks ..
Great info ..Thanks will now take off and align , could be a good job taday
Brownie
Old Nov 9, 2020 | 12:09 PM
Brownie12's Avatar
just what I needed ...thanks for your help
Nz Brownie
Old Nov 10, 2020 | 05:05 AM
Well do you have a Shop Manual for that car? My friend had a 1963 Buick Riviera he bought from the original owner family. (I know different car-- but...). This car had a broken bolt which holds the center bearing. Him and I Took out the whole 2 piece drive shaft to get out the broken bolt. I was the "Expert" here as I was a old mechanic years back. How smart I was to notice the shafts were out of phase- everyone knows the u joints need to be in phase! But since he had the manual we looked it up. Guess what the shaft were supposed to be out of phase- even showed how to set it up just exactly as it was set when we took it apart. Replaced broken bolt and all was fine. Good luck and let us know how it goes!
Old Nov 11, 2020 | 12:03 AM
Brownie12's Avatar
Hi there
thanks for info ...adds to my confusion 😊😊😊
no workshop manual as yet ...got one on the way hopefully , things take time to get to New Zealand at the mo .
will stay in touch
Brownie
Old Nov 13, 2020 | 02:40 PM
Brownie12's Avatar
Solved
Originally Posted by Brownie12
Hi there
will stay in touch
Brownie
Yea gidday,
got it sorted once I got the car up on stands so I could get a decent look . The center bearing/slip joint was not in line with rest of drive shaft, the back uj was not tight , replaced diff pinion seal as well. Slip joint does have a master spline and Yes the drive shaft is meant to be out of phase ,,,thanks Greg.
cannot test yet as still rebuilding carb and dizzy
NZ Brownie
You can see master spline at the 5 oclock mark
This looks factory
CueballGreasersCC
May 7, 2018 07:00 PM
1of1442
Apr 4, 2018 08:51 AM
jaygeedon
May 23, 2011 12:59 PM
501Paratrooper
May 21, 2011 06:54 AM
58Chromesmobile
Aug 18, 2008 08:57 PM
