When to use low vacuum modulator on TH400?
Old Feb 9, 2026 | 12:32 PM
MPSax's Avatar
How low is your vacuum before starting to consider changing the modulator to a low vacuum version vs stock?
Going on a 1969 TH400
Old Feb 10, 2026 | 02:32 PM
I would guess when the vacuum is low enough to prevent it shifting correctly.
I have built some 400s that went behind some pretty rowdy with bottom of the page cam grinds, and never needed a fancy modulator. How much vacuum do you have and what problems are you having?
Old Feb 10, 2026 | 03:03 PM
If you have enough vacuum to run power brakes I think you should be fine without the low vacuum modulator.
Sep 23, 2024 04:59 PM
oldsguybry
22
Jan 8, 2018 10:44 PM
SkylinesSuck
Oct 22, 2011 10:54 PM
TripDeuces
Jun 8, 2011 08:24 AM
chivo80026
Jul 3, 2008 08:51 AM
