Leaky trans cable / coupler and pan help!
Old Apr 24, 2025 | 10:25 AM
eggydrummer's Avatar
Hi all,
I have a leak that seems to originate from the trans pan on my 1961 Olds 98. The drip is coming off of what looks to be a coupler. It is pictured below. I have a few questions:
1) Is the silver 'coupler' just that? What is its function?
2) I think this cable runs up to the odometer. Is that correct?
3) How tough is it to replace the trans pan gasket? Is it a simple 'drop and replace' job?
4) What gasket material would be best if that is the case? Some gasket maker, or an actual gasket (cork, rubber?)?
Thank you all. This is new territory for me and this transmission leak.
Old Jul 23, 2025 | 06:55 AM
JOHNNYOLDS442's Avatar
Olds Specialist LOL
Yes should be cork /rubber pan gasket about $15 bucks
speedo cable has an o ring & small seal gasket both pretty easy just messy Youtube is your friend.
Chuxter
Apr 22, 2024 06:25 PM
Bfg
Aug 22, 2015 10:23 AM
jankyrre
Jan 31, 2015 07:28 AM
Arrowstorm
Aug 14, 2014 04:07 PM
txrob779
Feb 11, 2014 11:01 AM
