Shudders in reverse when cold
Hi everyone,
I have 1968 442 with 400/400. Can you tell me why I may have developed a shudder in reverse when it is not completely at running temp ? I have a drip at the pinion gear when it sits for a bit, but it seals up when I drive it.
Thank you for any info.
fluid level?
fluid level is good? I am assuming you checked that, forward is no issue I am also assuming? because the fluid heats up a little gets thinner and flows easier, so maybe a tranny service is in order, gunk build up maybe on the filter? but only in reverse is also puzzling if thats the case.
