Shudders in reverse when cold
Old May 18, 2020 | 06:02 AM
jonnyslim63's Avatar
Hi everyone,
I have 1968 442 with 400/400. Can you tell me why I may have developed a shudder in reverse when it is not completely at running temp ? I have a drip at the pinion gear when it sits for a bit, but it seals up when I drive it.
Thank you for any info.
Old May 18, 2020 | 08:36 AM
Is it an engine shudder or a drivetrain shudder. It could be the passenger engine mount, trans mount, Ujoint, etc... Or if its engine, check your tune up settings.
Old May 18, 2020 | 08:38 AM
Thank you.
Drivetrain, and only when cold.
Old May 18, 2020 | 08:53 AM
My Dad and Grandpa from Muscogee by the way.. not too far from you. Grandpa moved to Eagle River Alaska then retired back to Grand lake.
Old May 18, 2020 | 10:03 AM
Not to far
Old May 18, 2020 | 03:45 PM
Eddie Hansen's Avatar
fluid level?
fluid level is good? I am assuming you checked that, forward is no issue I am also assuming? because the fluid heats up a little gets thinner and flows easier, so maybe a tranny service is in order, gunk build up maybe on the filter? but only in reverse is also puzzling if thats the case.
Old May 18, 2020 | 06:27 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Im lazy let's try this: This is out of my Motors Trans Manual.
Old May 21, 2020 | 07:22 AM
It's not slipping. It just has a weird vibration when first drive. Gonna get rear end serviced.
thanks for taking the time
Old May 21, 2020 | 07:23 AM
Yes, thanks for reply. fluid levels good. Im gonna have the rear end serviced. i was told it had been done not long ago, but.....gonna do it anyway
Old May 21, 2020 | 12:23 PM
gs72's Avatar
72Cutlass S
Maybe the rear brakes aren't releasing all the way when you release the parking brake and are dragging. then when you move is forward they retract and the problem is gone.
Old May 21, 2020 | 12:54 PM
DUH. I had similiar situation on my 68 El Camino where the E Brake actuator was freezing and eventually froze.. good point. Ill check that. THANKS!
oldolds88
Apr 14, 2018 06:41 AM
Draven
Jan 19, 2012 08:37 AM
442olds68
Oct 2, 2010 09:18 PM
pgh442
Aug 2, 2009 09:36 PM
gthmcty1
Drivetrain/Differentials
Jul 23, 2009 02:54 PM
