Shudders in reverse when cold
Old May 18th, 2020, 06:02 AM
jonnyslim63's Avatar
Hi everyone,
I have 1968 442 with 400/400. Can you tell me why I may have developed a shudder in reverse when it is not completely at running temp ? I have a drip at the pinion gear when it sits for a bit, but it seals up when I drive it.
Thank you for any info.
jonnyslim63 is offline
Old May 18th, 2020, 08:36 AM
Is it an engine shudder or a drivetrain shudder. It could be the passenger engine mount, trans mount, Ujoint, etc... Or if its engine, check your tune up settings.
oldcutlass is online now
Old May 18th, 2020, 08:38 AM
Thank you.
Drivetrain, and only when cold.
Old May 18th, 2020, 08:53 AM
My Dad and Grandpa from Muscogee by the way.. not too far from you. Grandpa moved to Eagle River Alaska then retired back to Grand lake.
Old May 18th, 2020, 10:03 AM
Not to far
Old May 18th, 2020, 03:45 PM
Eddie Hansen's Avatar
fluid level?
fluid level is good? I am assuming you checked that, forward is no issue I am also assuming? because the fluid heats up a little gets thinner and flows easier, so maybe a tranny service is in order, gunk build up maybe on the filter? but only in reverse is also puzzling if thats the case.
Eddie Hansen is offline
Old May 18th, 2020, 06:27 PM
CH3NO2 LEARN IT BURN IT
droldsmorland's Avatar
Im lazy let's try this: This is out of my Motors Trans Manual.
droldsmorland is offline
Old May 21st, 2020, 07:22 AM
It's not slipping. It just has a weird vibration when first drive. Gonna get rear end serviced.
thanks for taking the time
Old May 21st, 2020, 07:23 AM
Yes, thanks for reply. fluid levels good. Im gonna have the rear end serviced. i was told it had been done not long ago, but.....gonna do it anyway
Old May 21st, 2020, 12:23 PM
72Cutlass S
gs72's Avatar
Maybe the rear brakes aren't releasing all the way when you release the parking brake and are dragging. then when you move is forward they retract and the problem is gone.
gs72 is offline
Old May 21st, 2020, 12:54 PM
DUH. I had similiar situation on my 68 El Camino where the E Brake actuator was freezing and eventually froze.. good point. Ill check that. THANKS!
oldolds88
April 14th, 2018 06:41 AM
Draven
January 19th, 2012 08:37 AM
442olds68
October 2nd, 2010 09:18 PM
pgh442
August 2nd, 2009 09:36 PM
gthmcty1
Drivetrain/Differentials
July 23rd, 2009 02:54 PM
Quick Reply: Shudders in reverse when cold
