1964 Axle flange
Old Jan 17, 2023 | 02:58 PM
330jetstar's Avatar
1964 Axle flange
Rebuilding the rear end and a previous owner had some work done and it appears they cut the axle flange in half and rewelded it back together. Where can i find one for my 1964 Jetstar88
Old Jan 17, 2023 | 06:53 PM
Charlie Jones's Avatar
Phantom Phixer
Good luck finding one.
My parts book says that this axle is all by itself, fits only 1964 Jetstar 88.
Factory part number is 383316.
Old Jan 18, 2023 | 03:18 AM
I'll bet one of the racing axle places (Strange, Moser) could make one if it comes to that... good luck.
Old Jan 18, 2023 | 04:08 AM
BillK's Avatar
What part are you calling the "axle flange" ??
Old Jan 18, 2023 | 06:12 AM
The Jetstar 88 rear axle housing is the same as the 8.2" axle housing used on the A-body cars, EXCEPT for the length of the axle tubes, which are longer for the wider B-body application. If you are talking about the flange at the outboard end of the axle tube, where the brake backing plate attaches, this is the same flange as used on every other 8.2" axle from that vintage. The bigger question is, if the flange has been re-welded correctly and is perpendicular to the tube and the bearing fits correctly, why mess with it? A proper weld is at least as strong as the parent metal.
drjaredshelton
Drivetrain/Differentials
Nov 8, 2022 05:49 PM
330jetstar
Aug 29, 2022 09:45 PM
pontiac1
28
Feb 19, 2022 10:07 AM
wim lesabre59
Oct 1, 2012 08:10 PM
Jetstar 88
16
Mar 15, 2012 06:21 PM
