200r4 to th400 swap 84 olds 98
Old Jun 30, 2024 | 05:40 PM
deltsanddueces's Avatar
So I 350 rocket swapped my 98 a while ago and I was never happy with the 200r4 so I’m in the middle of swapping that for a th400 and i went to put the driveshaft in and the yolks a different size. What size yolk is needed for a th400 and can I get a custom driveline place to swap the right yolk onto my existing driveshaft?
Old Jun 30, 2024 | 06:24 PM
Qwik71442's Avatar
Full-time Taxpayer
TH400 is a 32 spline yoke. yes, a driveshaft shop can make what you need.
Old Jun 30, 2024 | 06:42 PM
The driveshaft will also need to be shortened for the TH400
Old Jul 1, 2024 | 07:23 AM
even if it’s a short tailshaft th400?
Old Jul 1, 2024 | 07:29 AM
The short tail TH400 is about an inch longer than the 200-4R to the end of the case. Your original driveshaft may not have sufficient engagement on the output shaft.
Old Jul 1, 2024 | 09:37 AM
is it as simple as tellin the driveshaft shop to chop an inch off the drive shaft?
Old Jul 1, 2024 | 09:42 AM
The right way to do this is to install the trans first. With the rear suspension at ride height (weight on the rear springs), insert the front yoke all the way into the trans, then pull it out 1". Measure the center-to-center distance between the u-joints. That's the dimension they need.
yeahbuddy
Jan 27, 2020 02:40 PM
darksider415
Oct 9, 2015 10:11 AM
josh stowe
Oct 21, 2013 08:33 AM
grimlock
Jan 23, 2007 09:24 PM
JP63
May 19, 2003 02:05 PM
