1969 Cutlass -Column to Floor shifter
Need help. Changing from column to floor shifter and now she will not start. Changed out the neutral/backup switch for the new console then ran the wires to the existing column neutral safety switch under the dash. the connector under the dash was not the same so I spliced it in on the column. Any help would be greatly appreciated
