Borg Warner ST 10 shifter linkage kit
Which shifter install kit do I need to use for a ST10 transmission swap into a Cutlass? The linkage and shifter off a 70 Muncie won't work correct?
Hello All, New to the forum, however have been lurking for some time. The facts on here has clearly helped me purchase an A code 65 coupe in addition to make informed decisions on restoring it. However, I'm going for walks into a little street bump. I want to install a hurst Competition Plus shifter on my four pace Borg Warner T10 transmission. However, I am having problems locating the proper linkage set. I obtained linkage set 3737637 as a Christmas present, but after some studies I believe this may be the wrong set. In the Hurst ID for the transmission, it appears that my transmission may be 413 (their catalog identification). They kingdom that there may be no installation package for 413 ID and that linkage can also need to be fabricated or located used. My question is has anyone ever altered a linkage set or know where to find a linkage set that might paintings with my transmission? Any assist would be significantly appreciated.
Kodi
Kodi
