Borg Warner ST 10 shifter linkage kit
Old Feb 24, 2024 | 04:08 PM
Magna86's Avatar
Which shifter install kit do I need to use for a ST10 transmission swap into a Cutlass? The linkage and shifter off a 70 Muncie won't work correct?
Old Feb 24, 2024 | 05:59 PM
Hurst Competition Plus shifters fit Borg Warner and Muncie. You need the correct rod and lever kit for the trans. Look for the kit that fits the 74-81 F-body cars with the ST10.
Old Feb 24, 2024 | 08:11 PM
Magna86's Avatar
Thanks Joe..I had a feeling would be the F-body kit but wasn't sure.
Old Mar 19, 2024 | 04:21 AM
dsiaok's Avatar
Hello All, New to the forum, however have been lurking for some time. The facts on here has clearly helped me purchase an A code 65 coupe in addition to make informed decisions on restoring it. However, I'm going for walks into a little street bump. I want to install a hurst Competition Plus shifter on my four pace Borg Warner T10 transmission. However, I am having problems locating the proper linkage set. I obtained linkage set 3737637 as a Christmas present, but after some studies I believe this may be the wrong set. In the Hurst ID for the transmission, it appears that my transmission may be 413 (their catalog identification). They kingdom that there may be no installation package for 413 ID and that linkage can also need to be fabricated or located used. My question is has anyone ever altered a linkage set or know where to find a linkage set that might paintings with my transmission? Any assist would be significantly appreciated.
Kodi
Old Mar 20, 2024 | 07:47 AM
Run to Rund's Avatar
Super T10s generally have the stud and nut attachment at the shifter arms in the transmission. Later Muncies have the bolt attachment so the levers are different.
oldsmoboogie
Jan 22, 2022 11:18 AM
babs68
Jul 24, 2017 07:42 AM
64Rocket
Jun 23, 2011 10:18 PM
strumagic
Dec 7, 2004 10:17 AM
strumagic
Mar 1, 2004 10:08 AM
