Jetaway transmission leak
Old Feb 23, 2025 | 08:09 AM
AK Cutlass's Avatar
I have a small leak from the front seal of my 68 Cutlass Jetaway transmission. It's probably because it was in storage for over 30 years and the seal has hardened. I plan to eventually remove the transmission and go through it but in the meanwhile the transmission is operating as it should and I would like to drive my car for a while before tackling that project. Any recommendation or experience with a stop-leak supplement that will not damage the trans and stop the leak until I can get around to pulling it.
Old Feb 23, 2025 | 08:13 AM
I would just drive it as is and periodically check and add as required if the leak is small.
Old Feb 23, 2025 | 12:39 PM
redoldsman's Avatar
Proud Viet Nam Veteran
Put a drip pan under it and keep a check on the fluid.
Old Feb 23, 2025 | 12:44 PM
JohnnyBs68S's Avatar
^^ +1. It's hardly worth rebuilding, a TH350 upgrade is a minimum if it has to be pulled. If its the rear seal or speedo gear housing seal leaking, that's easy to replace without removal. Just don't let it run low on fluid, it'll let you know when it does.
Old Feb 23, 2025 | 01:40 PM
AK Cutlass's Avatar
Already replaced the shift shaft seal and the pan gasket that reduced the leakage significantly so I guess I'll just put up with it and let it mark its territory.
hwalzer
Aug 27, 2021 07:33 AM
hwalzer
Aug 23, 2021 02:56 PM
Fred Utz
Aug 30, 2014 07:46 PM
D.B.
Aug 14, 2013 06:20 PM
Gary's 2 442-S
Sep 24, 2012 10:56 AM
