Crankshaft seal small leak
Old Aug 23, 2021 | 10:02 AM
hwalzer's Avatar
69 442 convertible
Has anyone used AT 205 stop leak in their engine? I have a small leak at the front crankshaft seal.
Old Aug 23, 2021 | 01:37 PM
Stop leak products work by softening and swelling the seals (all of them). It will temporarily stop or slow a leak, until the softer seal material wears out. Great for a car you're about to sell, not so much for one you care about.
Old Aug 23, 2021 | 02:56 PM
There is no reason to ask the same question in multiple forums. I doubt that will be effective for a crankshaft seal.
Old Aug 25, 2021 | 03:54 PM
F-85 4-4-2's Avatar
I'm no fan of stop-leak products, but they can be worth a try. In my 100k-mile 1990 GMC pickup, a pint of Lucas Oil oil-stop-leak, 5 years ago, stopped a drip for good. Lucas is a (synthetic?) petroleum, versus the seal-swelling solvents of yore. Lucas is mum about how it works.
And, I kid you not, the service manual for my 170k-mile 1995 DD actually says to try a radiator stop-leak before yanking the whole front end to replace the radiator. That fix also worked, for 40k miles; its new radiator arrived today.
Both cases were worth their respective $9 investments and 3-minute service times.
Old Aug 25, 2021 | 04:03 PM
bccan's Avatar
Permatex 82099 Leak Sealer Spray.
I have used it on oil pan end gasket to timing cover leak and it worked but a crank seal? No way I can think of to band aid that.
Old Aug 27, 2021 | 07:33 AM
67OAI's Avatar
Old(s)GuysRule
Best way to put an end to that type leak is to replace the seal and repair the worn area on the damper by either: 1. chuck the damper in a lathe and turn and polish if not too badly worn or, 2. install a repair sleeve on the damper.
bigrbandit
Jan 30, 2019 04:55 PM
defiant1
Aug 3, 2016 02:50 PM
truckerlary
Jun 19, 2015 02:16 AM
VinMichael
Oct 18, 2013 05:26 PM
