Crankshaft seal small leak
Stop leak products work by softening and swelling the seals (all of them). It will temporarily stop or slow a leak, until the softer seal material wears out. Great for a car you're about to sell, not so much for one you care about.
I'm no fan of stop-leak products, but they can be worth a try. In my 100k-mile 1990 GMC pickup, a pint of Lucas Oil oil-stop-leak, 5 years ago, stopped a drip for good. Lucas is a (synthetic?) petroleum, versus the seal-swelling solvents of yore. Lucas is mum about how it works.
And, I kid you not, the service manual for my 170k-mile 1995 DD actually says to try a radiator stop-leak before yanking the whole front end to replace the radiator. That fix also worked, for 40k miles; its new radiator arrived today.
Both cases were worth their respective $9 investments and 3-minute service times.
Best way to put an end to that type leak is to replace the seal and repair the worn area on the damper by either: 1. chuck the damper in a lathe and turn and polish if not too badly worn or, 2. install a repair sleeve on the damper.
