PDA
View Full Version : Eighty-Eight
Pages : 1 2 3 4 5 [6] 7 8 9 10 11
  1. Disc brake options for -68 88 ?
  2. Vacuum Hose Connections for 1969 Delta 88
  3. What a difference 12 years makes
  4. Original mirror?
  5. Build sheet? found in door of car
  6. Vacuum temp switch to vapor canister hose
  7. 1957 Olds Super 88 2dr hardtop rear window regulators
  8. manual brake setup
  9. 1977 Olds Delta 88 for sale
  10. 1962 Dynamic Battery
  11. No brakes in a 69 88
  12. Hood liners
  13. Clock in a 67 Delta 88
  14. 1956 olds upper control arm bumper
  15. not much oil on rebuilt 371 camshaft
  16. 1972 Delta 88 scissor convertible top question
  17. 1956 olds suspension
  18. steering wheel fix
  19. BOw photos needed
  20. footwell bulb size?
  21. Vinyl or leather?
  22. 1968 Delta 88 or Custom
  23. 66 olds 88 dynamic
  24. 61-88. generator to alternator help
  25. 14" Tire issue..Wow they got pricey
  26. wheel offset & backspace 1961 dynamic
  27. Manual Trans for 1962 Dynamic?
  28. Adding gauge cluster to 80-85 Delta or 98
  29. 67 Delta 88 grill
  30. "61Dynamic 88 window trim info
  31. 425 c.i. 4 bbl manifold & carb.
  32. 1966 Delta 88 2 Speed Wiper Switch
  33. 1969 88 front seat donor car
  34. side mirror change??
  35. How much info goes thru the PCM?
  36. 78 Delta 88 wiper "Refills" ...
  37. Can someone tell me what they think these bumpers are worth?
  38. 1961 Dynamic 88 tail light?
  39. '67 Delta 88 pwr window motor needed!
  40. what is this called so i can get a new one....
  41. brake drums?
  42. maximum id for brake drums?
  43. 1961 88 ? Saginaw or TRW tie rod eds?
  44. 1956 oldsmobile headliner
  45. Vacuum wipers HHHHelp!!!!!!
  46. Power window/seat relay!
  47. interesting statement!
  48. 2bbl 324 surge
  49. tilt steering
  50. 1956 oldsmobile front outter wheel bearing help needed
  51. 1956 oldsmobile
  52. Cold air from the heat vents! Need visa versa!
  53. 1966 Delta 88
  54. Class 3 Trailer Hitch
  55. 1969 Delta 88 Royale
  56. Air cleaner help, 57 super 88
  57. 56 Power steering Conversion assitance
  58. Build locations
  59. my new super 88 holiday sedan
  60. My dream 65 Jetstar I
  61. Different rims for disc brakes?
  62. 1985 delta 88 steering wheel question
  63. Changing the carb out
  64. Key won't turn in ignition, can't remove cover either
  65. 56 olds undoing brake line help needed..tips
  66. delta 88 ..... bucket seats
  67. Performance Suspension Upgrades for 54-56 cars
  68. 1956 olds mystery
  69. eBay Delmont 88 auction
  70. Draged home a 54
  71. 1956 olds coil springs help needed
  72. Gots me some 20's, yo!!
  73. 73 delta 88 Power window switch needed
  74. Fuel Sending Unit for 1961 Dynamic 88
  75. neat pic
  76. Scissor Top R&R
  77. Did convertibles come with rear glass stock?
  78. Please help, 2nd request involving 1955, 56 Olds question
  79. 56 Olds rear suspension
  80. 84 delta 88 with a code 45
  81. 1956 oldsmobile power steering help needed
  82. Rear coil spring replacement
  83. 1956 olds front suspension help needed
  84. Need a replacement spring
  85. Door jam interior light switches can't find
  86. washer motor
  87. Shock advice for 1996 88....
  88. 55 s88 kingpin change
  89. 1958 Holiday Coupe Engine Color golden rocket V8
  90. Junkyard find: 1964 Dynamic 88
  91. Scissor top maintaince and lube points?
  92. 1973 delta 88 option list/brochure
  93. Well, I am the new owner of.....
  94. WTH? Great Dale House Car?
  95. 56 Olds Harmonic Balancer
  96. 55 s88 kingpin change
  97. any 68 's left in the real world?
  98. AC drain tube location
  99. Busted Convertible Top on my Delta 88 - Help
  100. Leak behind rear driver side tire (water)
  101. Trunk release issues
  102. Dyna 64
  103. 1956 88 int?
  104. 85 Delta 88 dash / w silverstar bulbs
  105. 77-85 Delta & Custom Cruiser body tag question...
  106. 69 88 topswitch
  107. 56 olds trim help needed
  108. 1980 Delta 88 Speedometer Cable Broken
  109. aluminium radiator
  110. Cool track pic!!
  111. 66 dynamic parts needed
  112. How much power?
  113. 1985 Delta 88 rear end
  114. assembly manual
  115. 57 Steering gear box
  116. huffnpuff2203 1969olds 88
  117. 57 Converts-All made in Lansing?
  118. More post-winter issues!
  119. 1965 delta 88
  120. 1969 0lds88convert or coupe side trim
  121. Starter grind
  122. Windshields.. Convrt vs Hdtp
  123. dash lights
  124. new wheels for a different look
  125. 65 Delta: Headlight switch removal
  126. Generator to alternator conversion.
  127. 71 delta 88 conv in junkyard
  128. '83 runs out of gas before gauge reads empty
  129. Rear deck removal???
  130. What's this worth? '55 88 Convertible
  131. The story of Wilard...
  132. Wiper delay adjustment
  133. 71 to 72 Delta 88 nose compatibility
  134. fuel lines...
  135. T/S switch install
  136. would there be any interest in 66 dynamic 88 convert parts?
  137. TN Rocket Man
  138. Fan shroud for 69 delta 88
  139. Headers for '67 with 425 engine
  140. Inlet manifold
  141. A/C info wanted for 54-56 cars
  142. 371 oil issue?
  143. 1959 Oldsmobile Outside Rearview Mirror - Style and Mounting Location
  144. Parts 66 vs 67
  145. Roof vinyl - 67 Delta 88 Holiday HT
  146. 1969 88 interior peices needed
  147. 1956 oldsmobile questions
  148. delta 88 wheel covers!!
  149. Delta 88 4 door vs 2 door fenders
  150. 84 olds delta 88 before and after pics
  151. Bumper trim
  152. 1956 olds carpet headliner seat covers help
  153. 1956 olds mystery holes
  154. 1953 Olds Super 88 wont start!!
  155. Chrome valve covers for a 62 Dynamic
  156. 85 Delta-84 impala
  157. Idea for double hump crossmember
  158. Shock replacement
  159. 1962 Dynamic 88 Convertibles
  160. POSSIBLE disc brake conversion for disc brake cars 67-70
  161. part # for a 394 thermostat housing
  162. Thermostat housing (water neck)
  163. Lowering spindles for a 1961 Dynamic 88
  164. Help needed with 73 Delta 88 conv. windshield trim removal
  165. SOLD today !
  166. 74 Delta Curb Weight
  167. Considering a 1950 4 door
  168. Speedo cable replace
  169. Window Seals - installation pics
  170. Coolant Puddle on engine block-78 Delta 88
  171. 1964 Olds 88 engine swap
  172. youth revisited! my newest find 1978 delta royale
  173. Latest Pic
  174. eBay replacement Carpet... Opinions?
  175. Bolt Pattern... 5X5?
  176. No heat, FIXED!!
  177. 72 delta fender question
  178. !955 power brakes
  179. New 1966 Delta 88 Owner
  180. economy fuel gauge
  181. 1956 olds holiday 88 4dr hardtop windshield help
  182. 56 olds no spark
  183. Production Question for 1971 Delta 88 gurus
  184. No Heat
  185. 1983 Delta 88 I need some help
  186. regards
  187. 78 Delta 88 Royale resto.
  188. Splash guards
  189. obscure '75 Delta 88 question
  190. '62 88 two tone: roof line trim body color?
  191. new 88's leaving the yard
  192. 1970 Delta 88 parking brake cable routing
  193. 1969 88 delta frontbumper
  194. 52 Olds 88
  195. 69 2 door fuel ecconomy
  196. Will a the tailpipes from a dual exhaust 84 hurst olds fit a 84 delta 88
  197. 1973 asy line pics round #2
  198. 1973 asy line pics
  199. anyone in CA need an 85 Royale for parts?
  200. Dieseling- does it get worse before it gets better?
  201. How to get this out
  202. need a windshield
  203. Headlight plugs
  204. 85 Delta 88 lower or stock height?
  205. Fianally getting started
  206. 74 delta Royale cowl tag
  207. opera light compatibility
  208. 64 or 65? Jetstar 88
  209. My power steering whines... whats up
  210. Firing order
  211. I would like to introduce, Dexy the Delta
  212. Power bench seat ?
  213. Transmission Fluid Question
  214. Pertronix Ignition Installation Question
  215. 1963 Dynamic Convert side trim wanted
  216. 1958 Oldsmobile Tail Lights
  217. A walk away from sale.
  218. Jack location in trunk?
  219. Smoking a bit too much
  220. Rocket, Super-Rocket, High-Compression?
  221. 71 royale conv seats
  222. Base Idle Speed... tapping sound.
  223. Opinions on '70 Delta 88
  224. Gas Mileage?
  225. 65 Oldsmobile interior manuals available?
  226. My 65 Delta
  227. 65 oldsmobile convertible 4 speed car?
  228. Oil '78 350 ...
  229. My next little problem - gas gauge!
  230. More throttle = more heat?
  231. erratic running under load
  232. Interior lighting question
  233. Intake manifold for 4brl 64 88
  234. new carb, new plug...
  235. 1974 88 pwr window wiring help
  236. 83 Delta 88 swap possibilities.
  237. Another Headline question
  238. "Tire Magic" on vinyl top?
  239. Starter won't stop on 64 88
  240. 84 Delta 88 Royale
  241. Bumper Trim
  242. Converting to quad carb - 67 Delta
  243. Fuel pump going?
  244. 1969 delta 88 convertible top switch
  245. electrical question
  246. My continuing battle vs my heating system!
  247. Leaking gas tank at bottom 74 olds
  248. quarter mile time of a '65 Delta?
  249. Blower Switch Wiring
  250. Water valve routing
