Headlight plugs
Old Nov 10, 2011 | 02:03 PM
Redog's Avatar
Headlight plugs
OK I found out that one of highbeams isn't out like I thought it was, the plug doesn't connect that well.
My question is, are all the headlight plugs the same in GM cars of the late 70's early 80's? The junkyard I go to has a lot of Caddies there with the same type of 4 x 6 1/2 headlights the 85 Delta has.
I think yes, but I want to confirm first
Old Nov 10, 2011 | 05:11 PM
Lady72nRob71's Avatar
99.99% sure!
Old Nov 10, 2011 | 07:25 PM
Sure, they're all the same, but why not just take 5 minutes to clean the corrosion off the one you've got?
Just use a small screwdriver to depress the retaining tab and pull the terminal out of the plug, and wire brush it clean (a Demel is great for this), then snap it back together.
Old Nov 10, 2011 | 09:57 PM
Redog's Avatar
I don't think rust or corrsion is my probelm, the plug in question is very loose
Old Nov 11, 2011 | 02:58 AM
So remove the terminals from the plug and gently squeeze them tighter with a pair of pliers.
Old Nov 11, 2011 | 03:05 AM
Yellowstatue's Avatar
And another thing you can do is give the tangs of the headlamp a little twist (CAREFULLY) with a pair of pliers in opposing directions...this will give you a more firm connection... I have also done this to Muskrat's Alero with success...
bob p
Apr 10, 2015 01:55 PM
Redog
Jun 25, 2012 08:14 PM
Tom Bilse
Dec 12, 2010 03:25 PM
wagonman
Mar 7, 2008 06:49 AM
sbs4332
Feb 28, 2008 02:25 PM
