PDA
View Full Version : Eighty-Eight
Pages : 1 2 3 4 5 6 [7] 8 9 10 11
  1. Blower resistor
  2. What is this connector?
  3. Defroster in a 67 Delta 88
  4. Need help with gear shift indicator
  5. 80-85 brougham top trim replacement
  6. Valve cover sticker
  7. Convertible Top Leak/Drain Help
  8. Rear bumper interchange
  9. Future 4 Speed Project - Someone ever done this?
  10. Rechroming plastic
  11. whats the difference
  12. Hood liners
  13. 1957 88 body
  14. Tire Size for 67 Olds Delta 88
  15. 1968 Delta 88 2 door coupe. metallic blue
  16. Any such thing as a good portable sound system
  17. 1981 Delta 88
  18. OK how do I patch this?
  19. Door seal replacement
  20. '66 Jetstar suspension/steering issues
  21. What are bumpers made of?
  22. 50K Hei Distributor question '78 350 88 ...
  23. Thoughts on modern stereo systems in an old car
  24. 1970 2 door 88 in the yard
  25. What is the Air Injection Reactor?
  26. Fuel filter
  27. Help finding a heater control valve?
  28. Steering gear
  29. 74 delta 88 convertible
  30. Converting my 67 Delta 88 to dual exhaust
  31. 67 Delta 88 - yes more questions!
  32. 67 Delta air filters
  33. 1979 headliner?
  34. 67 Delta 88
  35. timing a delta 88 350 2 bl
  36. 84 delta 88 trans crossmember
  37. 56 olds fuel pump
  38. 1978 Delta Power Door-Locks Question ...
  39. Gas tank leak?
  40. A/C high and low side?
  41. olds 66' Delta 88 (need parts)
  42. 1972 Delta Royale gas tank
  43. Question about front turn signals
  44. Cruise Control not working
  45. headlight switch pigtail connecter
  46. 1967 Delta 88 Holiday Trunk Panel for sale
  47. 1978 Delta Royale 350 Questions ....
  48. Rear size width MAX
  49. Check this OUT!!! Delta's 88
  50. 63 Dynamic 88 Holiday Questions
  51. Body filler removal
  52. Will Oldsmobile rally wheels fit on a 1973 Delta 88 conv?
  53. Will these rims fit???
  54. Base, Custom or Holiday?
  55. Heater Core Installed!
  56. pigtails sockets
  57. Looking for opinions on car covers
  58. Short vid of my 65 Jetstar
  59. Holiday 88 oil gauge
  60. How to: window motor
  61. How to: heater core
  62. Power Window Motor
  63. 1964 dynamic hydro-matic shifting issue
  64. Cooling system capacity
  65. 307 hard to turn over
  66. 394 Fuel Pump Air Dome
  67. 1969 feul gauge
  68. Broken accellerator (gas) pedal
  69. Tire Size
  70. Changing Out Rubber parts of Fuel System
  71. 1985 Delta 88 A/C box leak
  72. 1967 delta 88 boot snap down clip
  73. Harrison Air Conditioning Label
  74. Dash pad removal?
  75. parts to netherlands through buffalo
  76. My Data and Protect-O-Plate
  77. My first Project car
  78. What's the difference?
  79. fuel sending unit fix
  80. Dashpad for a '67-'68 B-body Olds
  81. 64 Dynamic 88 4dr.
  82. 1963 88 wheel/tire upgrade
  83. new Package tray for 1965
  84. Missing power option ?
  85. 1978 88
  86. 74 delta door panel help
  87. 1970 W33 has good new home
  88. Thermal Switch
  89. wire wheels
  90. The " Last" Delta 88 found !
  91. Engine question
  92. Delta wheel size?
  93. Removing rear seat on '65 Delta 88 sedan
  94. 1969 88 delta frontbumper
  95. 1973 and74 delta 88convertibles
  96. Ign key to starter wire under dash
  97. Custom Rims & Tire Size On A `71 Delta
  98. convertible top parts
  99. which had color intake manifold
  100. 56 Super 88 help in translating plate and vin
  101. Delta 88 vs. Royale ?
  102. Gear shift selector problem
  103. 74 delta 88 vert
  104. Vent Window Assemblies - 54-56
  105. VIN Locations - 1956
  106. HELP!!! asap
  107. overdrive
  108. What is the bulb size???
  109. Chop top ? Is it a sin ?
  110. Windshield washer pump troubleshooting
  111. 72 Delta Royale
  112. Oil pressure switch with light
  113. 69' delta accelerator throtle cables
  114. 74 delta 88 vert
  115. Loose dash lights
  116. 74 delta 88 vert
  117. 1973 paint name
  118. 56 Brakes
  119. J2 tri power intake
  120. 1966 Delta 88: Should I buy it?
  121. 1965 Fuel tank
  122. power seat transmission
  123. HID lighting
  124. Hub cap center emblem color
  125. 3900 mile '75 88
  126. Where to get a tailpipe
  127. 1963 88 right side mirror
  128. '55 olds diff width??
  129. New muffler???
  130. 307 air filter snorkel delete
  131. 1980 Delta Holiday 88
  132. 68 delta 88 front left wheel spindle question
  133. 1961 Dynamic 88 Convertible
  134. A 1971 442 Tribute In Progress...On A Delta ! Vids...
  135. 1963 Super 88
  136. delta 88 royale clock removal
  137. 55 olds idle question
  138. 307 cold start issues
  139. Headliner replacement
  140. How to hook up Holiday 88 gauges
  141. Value of a '67 88 ragtop
  142. trying to verify research
  143. Can't go wrong for $1200.
  144. How many registered?
  145. rusted door latches
  146. 1969 whiper question
  147. Just cuz I like it
  148. '55 olds replacement heater core.
  149. 1969 88, what you think its worth?
  150. cow tag
  151. 55 88 dual exhaust info.
  152. Bias vs Radial Tires for 1950 88???
  153. Heater Core
  154. Hot '66 dynamic 88 vert
  155. 1965 starfire/88
  156. Delta 88
  157. 75 delta 88 royale headers
  158. Ride in the Starfire
  159. brake question
  160. Starfire adjustable sterring column.
  161. Seeking owner of this '71 Delta 88 Royale
  162. My 1962 Olds Super 88
  163. 55 Olds Speedo Problems
  164. 1964 Starfire Gas Tank up date
  165. 78 Delta 88 Royale Body Service Manual
  166. Core support bushing
  167. love those german autobahn
  168. 1969 delta 88 feul dash unit
  169. I might have broken my timing chain
  170. 1961 Oldsmobile Bubble Top
  171. Pitman arm help for a '64?
  172. info convertible top
  173. 67 "88" question
  174. 63 Starfire Turn Signal
  175. 1974 Delta 88 convertible parts lead
  176. Starfire Fuel Tank
  177. grill of a 1969 delta 88
  178. MARCH 2011 Issue of "Hemmings Motor News"
  179. Question about replacing the Accelerator pump on my 83 delta 88
  180. Are the Chrome trim pieces on a 1983 Delta 88 Glued On or??.
  181. power steering
  182. How do you take out the gauge cluster to grease the speedometer?
  183. Radiator Problems
  184. drumbrake spindels
  185. 65'Delta 88 weatherships
  186. 55 88 max wheel size?
  187. Delta 88 timing
  188. info
  189. carbs - stock vs. aftermarket
  190. Need help. 66 Dynamic engine code
  191. '68 Olds full size under the rear seat panels
  192. How much to repair & re-chrome bumper
  193. 1964 super 88
  194. heater control valve
  195. 78 Olds Delta 88 Royale Heater Problem
  196. Looking for parts need HELP!
  197. backspacing of a SS4
  198. Door hinge cage nuts
  199. 1956 Super 88 Convertible fisher body tag
  200. 1956 Super 88 Convertible Trim TAG
  201. 65 jetstar 88 with 425 installed
  202. Rear Diff question
  203. New Steering Box
  204. Possible disc brake solution 70 88
  205. tank capacity
  206. Collectible Automobile Feb 2011 issue..Big Olds '65-66
  207. A little more trouble with wheel studs..
  208. Parts needed 74 Olds 88 2 dr. convert
  209. "She took my Oldsmobile" Song
  210. New tires/wheels for the 88
  211. Vin #
  212. Little problem with wheel studs..
  213. 62 SUPER EIGHTY 8 (Newbie needs to know)
  214. Heater core
  215. front suspension torque specs
  216. some kool pics of the 70
  217. 55 88 4dr holiday
  218. Christmas?
  219. Low Compression 394
  220. Thanks everyone!
  221. Interchangable?
  222. Info on Delmont 88
  223. 1973 delta 88 suspensions
  224. Body side molding differences
  225. 1961 Olds Dynamic 88 "Bubble-Top"
  226. 1964 Jetstar 88 Steel Wheel
  227. Random Delta 88 Road Trip Vid
  228. clock delete?
  229. 1969 delta 88 taillight lenses
  230. J-88 wheel
  231. Frontbumper 1969 Delta 88
  232. 1965 Starfire quarter panel interchange
  233. cowl tag decode
  234. Hubcap question???
  235. 1965 delta 88 transmission
  236. Big 88 Custom
  237. Production #s for 69 delta 88 ragtop
  238. 64 dynamic 88 vert
  239. '68 Delmont Ventillation Vacuum Diagram desperately needed!!!
  240. '78 88 interior
  241. cowl id plate decode
  242. Cowl tag question
  243. Anyone know of a source for a cruise control servo or a repair service?
  244. passenger mirror
  245. Having problems with my washer pump not stopping.
  246. Just paid for the most expensive tube of lubricant for my window seals.
  247. what kind of dual exhaust did you use
  248. 1966 oldsmobile delta 88 convertible
  249. '68 Delmont 88 Convertible
  250. Tire Size?
