74 delta 88 convertible
Pull the interior trim panels off (fairly big job) and get a look inside at the tracks and regulator. Usually either the tracks are dry and the nylon rollers are worn out or the tracks are rusted apart. If the tracks are in good shape, you can pull the regulator, replace the rollers and grease the tracks. If the tracks are rusted badly, you'll need to replace the whole regulator assembly.
pull the interior trim panels off (fairly big job) and get a look inside at the tracks and regulator. Usually either the tracks are dry and the nylon rollers are worn out or the tracks are rusted apart. If the tracks are in good shape, you can pull the regulator, replace the rollers and grease the tracks. If the tracks are rusted badly, you'll need to replace the whole regulator assembly.
JoshF85
Jun 1, 2024 09:20 PM
Dead Reckon
Mar 4, 2016 10:55 AM
Aussie67Delta88Custom
Feb 22, 2008 04:49 AM
