74 delta 88 convertible
Old Aug 9, 2011 | 07:35 AM
delta254's Avatar
I'm havin trouble with the qtr windows staying in tract they fall or get off track when i roll them up or down any suggestions on were to start please help thanks guys?
Old Aug 9, 2011 | 12:17 PM
copper128's Avatar
Lt. Buzzkill (ret.)
Pull the interior trim panels off (fairly big job) and get a look inside at the tracks and regulator. Usually either the tracks are dry and the nylon rollers are worn out or the tracks are rusted apart. If the tracks are in good shape, you can pull the regulator, replace the rollers and grease the tracks. If the tracks are rusted badly, you'll need to replace the whole regulator assembly.
Old Aug 9, 2011 | 12:34 PM
delta254's Avatar
Originally Posted by copper128
pull the interior trim panels off (fairly big job) and get a look inside at the tracks and regulator. Usually either the tracks are dry and the nylon rollers are worn out or the tracks are rusted apart. If the tracks are in good shape, you can pull the regulator, replace the rollers and grease the tracks. If the tracks are rusted badly, you'll need to replace the whole regulator assembly.
ok everything is off i can look at the motor the tracs im trying to figure out how they work?
JoshF85
Jun 1, 2024 09:20 PM
2blu442
Jan 31, 2021 06:27 AM
Dead Reckon
Mar 4, 2016 10:55 AM
Bigball
Mar 24, 2012 05:09 AM
Aussie67Delta88Custom
Feb 22, 2008 04:49 AM
