Core support bushing
Old Mar 20, 2011 | 04:57 AM
jozw30's Avatar
When I bought my 55 88 sedan, the front clip was removed. Can someone tell me if the front core support to frame bushing is the same as the other body mounts?
If it's not the same, does anyone sell a replacement?
Thanks,
Joe
Old Mar 26, 2011 | 06:57 AM
tpawlik's Avatar
I could not find core support bushings for my 62 Starfire. I used body mount bushings. They worked fine. When you start to reassemble the sheet metal parts leave the fasterners a little loose until you mount the fenders. I could have used c couple of shims. My left fender is about 1/8" lower than the right. It will be difficult to adjust now that everything is assembled.
I found the best assortment of rubber mounts at Ames Performance Engineering. They specialize it Pontiac parts, but a lot of what they sell will work on an Olds.
jensenracing77
Jan 25, 2018 04:16 PM
oldsguybry
Body work
Feb 24, 2015 03:56 PM
rcktdoc
Jul 14, 2014 12:38 PM
scubastever
May 5, 2009 01:20 PM
