Core support bushing
Old March 20th, 2011, 04:57 AM
jozw30's Avatar
When I bought my 55 88 sedan, the front clip was removed. Can someone tell me if the front core support to frame bushing is the same as the other body mounts?
If it's not the same, does anyone sell a replacement?
Thanks,
Joe
jozw30 is offline
Old March 26th, 2011, 06:57 AM
tpawlik's Avatar
I could not find core support bushings for my 62 Starfire. I used body mount bushings. They worked fine. When you start to reassemble the sheet metal parts leave the fasterners a little loose until you mount the fenders. I could have used c couple of shims. My left fender is about 1/8" lower than the right. It will be difficult to adjust now that everything is assembled.
I found the best assortment of rubber mounts at Ames Performance Engineering. They specialize it Pontiac parts, but a lot of what they sell will work on an Olds.
tpawlik is offline
jensenracing77
January 25th, 2018 04:16 PM
oldsguybry
Body work
February 24th, 2015 03:56 PM
rcktdoc
July 14th, 2014 12:38 PM
scubastever
May 5th, 2009 01:20 PM
Quick Reply: Core support bushing
