PDA
View Full Version : Eighty-Eight
Pages : 1 2 3 4 5 6 7 [8] 9 10 11
  1. 1967 Delta 88 cowl tag decode
  2. found a rear end not sure if it right help
  3. Delmont 88 425 and 455
  4. Orig/Repro Wiper blades for 57 Super 88
  5. What Wheels and Tires would you get for '66 Dynamic 88 vert?
  6. 1977 88 pace car
  7. Knocking on 455 2bl
  8. Antifreeze Burp
  9. transmission type request
  10. two tone paint
  11. 60 Super88 Dash Pad
  12. '61 Fullsize-- With No Backup Lights?
  13. Valve Cover paint
  14. Best off staying stock?
  15. 0-60 time
  16. Hello to all the BIG Olds Owners!!!
  17. 57 Radio Antenna
  18. Temperature sensor removal
  19. 1954 fuel tank removal
  20. Side Mirror
  21. 77 Indy Pace - # inside drivers jamb ???
  22. Exhaust info needed
  23. Posts....
  24. Looking For Small Parts
  25. What do these do?
  26. locating parts
  27. bolt pattern change
  28. Flasher Tung-Sol P 273 D replacement
  29. 1967 Delmont 88 Kick Down Relais?
  30. 57 Super 88 breather tube
  31. want to install glasspacks on my 84 olds delta 88
  32. Oil purging from dipstick???
  33. What motor is this?
  34. Wheels, bolt pattern
  35. Seat Belts in a 57 Super 88
  36. code 42 84 olds delta 88 307
  37. 67 delta w/ oia
  38. 1966 88 2 door part car
  39. Mecum auction Weds 5/19
  40. Battery size
  41. radiator schroud 69 delta
  42. 68 delmont, springs
  43. My 1960 Dynamic 88
  44. "8" emblem from a 1950ish? Olds.
  45. Gas tank trouble
  46. radiator schroud
  47. 68 delmont bumpers
  48. Air Shocks on a '61-'64 88
  49. 1977 olds pace car 88
  50. Removable Roof Racks with Suction Cups
  51. How is the best way to raise the bench seat?
  52. Performance upgrades for a 307 82' delta 88
  53. 88 or s 88?
  54. Carb Flooding After Hard Acceleration
  55. heater cables
  56. How many of you have/had 88's with a 4bbl
  57. 1984 oldsmobile delta 88 307 throwing code 13?
  58. problems with lock-up torque converter and o2 sensor 84 delta
  59. Can a stock delta 88 do a burnout?
  60. New wheels n tires on my 88
  61. Vacuum line location
  62. 67 or 68 delta custom ?
  63. Center link for '64 Jetstar Convertible?
  64. Side trim for 49 help please
  65. Turn signal lever on 83 delta 88
  66. tail light
  67. What head lights for a 49.
  68. 371 to 425 or 455 swap
  69. Help: Fuel tank for Oldsmobile Dynamic 88 1966
  70. Need some carb help s.e. Michigan
  71. 1970 distributor dwell specifications
  72. 1973 delta 88 conv
  73. Decode Built sheet Oldsomobile 88 1966
  74. Now this is a G-machine!
  75. headrest removal
  76. 1969 Delta 88 Convertible
  77. My 60 88 project..
  78. Rocker molding clips
  79. Pics of my '64 Jetstar 88
  80. 1965 Delta 88 history
  81. Jetstar88 Disc Brake Conversion?
  82. 1952 Oldsmobile intake manifold 3x2
  83. help with delmont 88
  84. 394 cid fuel questions
  85. pic of my 60 olds dynamic 88 project
  86. 56 Olds 88th Wiring/Electrical Diagram
  87. 65-70 Speedometer Cables, who needs one?
  88. 1961 Olds 88 2 door hardtop for sale
  89. my 55 88 needs a part
  90. 1956 Olds Holiday 88 fuel tank
  91. Newly inherited '94 D-88 Royale with issues.
  92. w33 70 Delta new question
  93. '85 Delta 88 dies when put in gear....
  94. New Pictures off my 66 Dynamic 88 :-)
  95. what year engine parts interchange with my 60 371
  96. parts needed for my 60 88
  97. Its been a while....
  98. introduction and pics of my 73 delta 88 conv
  99. do they make performance parts for the 371
  100. making a custom billet grille for my delta 88
  101. new guy from lompoc ca with a 1956 olds
  102. new to big oldsmobile scene, just drugg in a 60 olds 2 door dynamic 88
  103. My 1955 88 "Lady Lou" Needs a Radiator
  104. hot air coming out the bottom vent and cold air out the top vent? 84 delta 88
  105. 72 delta 88 rear width
  106. Hiding places in the B Body 88's
  107. **New '62 Dynamic 88**
  108. Build sheet location
  109. 63' 88 dymanic holiday
  110. 69' 88 delta rear axel an other questions
  111. 1970 w-33 delta custom
  112. 1962 Oldsmobile Dynamic 88 Conv
  113. how to remove and replace a heater core 84 olds delta 88
  114. 83 Delta 88 questions
  115. got my 69' delta88 back
  116. does a 1984 olds delta 88 have a standard or limited slip differential
  117. 1956 Oldosmobile 88 steering gear box
  118. Things I cant seem to find
  119. 394 header flange for custom dual exhaust
  120. 50 Olds coupe & a 425 365hp??
  121. Greetings 1972 Ninety Eight Regency
  122. R&R Heater core
  123. 97 LSS Climate Control
  124. anyone race their cars?
  125. U-Clamp for Ujoint for 65 88!?!?!?!
  126. U-Clamp for 65 88!?!?!?!
  127. Deloris(82 Delta 88)
  128. THAR SHE BLOWS!
  129. 55 Olds parts wanted
  130. Difference: 88 - Super 88 1957
  131. 57 Olds fiesta rear bumper
  132. '71 88 power brake booster
  133. '57 88 roof rail?
  134. part # location on fuel pump
  135. '66 Delta 88 Weight?
  136. Roller rocker questions
  137. Template O L D S M O B I L E Letters
  138. Introduction & pics of my 64 Jetstar 88
  139. 84 olds parts question
  140. New guy with a 51 Super88
  141. 1964 DYNAMIC 88 ****CARB QUESTION****
  142. Turn signal actuator
  143. ... transmission question
  144. Gen Light coming on...
  145. ONE LONELY PART
  146. Headers ?
  147. 1969 Olds 88 what other makes spindles fit?
  148. 1960 88 2 door hardtop
  149. new member with a 65 delta 88
  150. PICS 71 DELTA 88 ROYALE
  151. LH Muffler Hanger
  152. 1968 delta 88
  153. What wheels would you put on?
  154. Directional Switch
  155. new guy in Ga
  156. novice again needs help - gas tank
  157. DELTA 88 Details
  158. my front spring are broken
  159. PLEASE HELP/73 DELTA 88 ROYALE PARTS
  160. 73 Delta 88 frame interchange?
  161. 1962 Super 88 4 Door
  162. New Kid
  163. 1965 Delta 88, Jetstar 1, and Starfire found in yard
  164. Delta 88 emblems
  165. 1955 diff locating pin size required and U bolt diameter.
  166. A few questions about converting 2bll to 4bll
  167. 600 CFM Four Barrel for a 307
  168. 307
  169. front shock absorber removal -- how?
  170. 51 88 deluxe
  171. headlight switch removal
  172. boot parts? for replacmenttop
  173. Holy gas tank, Batman!
  174. My 1980 Olds Delta 88 Royale
  175. 1970 delta 88 wheel size
  176. 1983 Olds Delta 88 Royale Brougham Tranny
  177. '64 88 2door
  178. how do I take this apart
  179. '66 Dynamic, should I?
  180. I love chrome, but...
  181. '63 Dynamic 4door
  182. 1966 Oldsmobile Delta 88 (Target Red)
  183. 1871 detla 88
  184. Transmission Pan Gasket 1955 88
  185. decode body and trim plate
  186. A/C Questions
  187. 1967 Delta 88 convertible
  188. Correct Oil Filter for Original Set Up?
  189. 67 delmont 88
  190. another german
  191. 55 Olds Super 88 Matching Numbers on Body Parts???
  192. new pics of 70 delta 88 "Charlotte"
  193. 1968 Olds Delta 88 4 Door $600
  194. 1955 88 IS ALIVE WHA HOOO!
  195. disc brakes update
  196. 1973 Delta 88 a chance..
  197. Question about 54 super 88
  198. bosch or ACdelco oxygen sensors for a 84 delta 88 need help
  199. Newbie needs some help!!!
  200. New guy with a 67 delta 88 convertable
  201. lousdelta88royale pics
  202. need help
  203. 54 Olds convertible
  204. 54 Super 88 Convertible
  205. WTB pass. side steering knuckle- '78 88
  206. 64 Jetfire Exhaust options
  207. WTB Floor mats
  208. Chugging uphill
  209. Newbie with a 64 Jetstar 88 in CT
  210. i need parts
  211. 1978 Delta 88 Royal
  212. New guy with Super 88
  213. Ignition question on 78 Delta (350R)
  214. Cowl Vent Drains
  215. workshop manual
  216. headers for my 60 wagon
  217. Build Sheet located!
  218. NEED PARTS FOR 1970 DELTA 88 and info
  219. I,m Back Again :-)
  220. Hi from Chicago!
  221. new n needs help
  222. Parts for 1978 Olds Delta 88 Royale
  223. Good evening Olds lovers
  224. Dexcool
  225. Eighty Eight LSS
  226. 73 Delta radiator
  227. order sheet pace car
  228. 75 Delta 88
  229. Pics of my 67 Delta 88
  230. roof splitting!!!!
  231. my 84 delta 88 needs a new transimission need help
  232. is it possible to add a turbo or supercharger to a 307 small block
  233. Is this your '65 Olds missing Protecto Plates??
  234. '65 Dynamic 88 holiday hardtop protecto plate
  235. Fit question 50 Olds Beltline molding
  236. True duals on an '84 Delta 88? Believe it!
  237. '66 Olds Delta 88 Interior Available?
  238. New member: D88 (the lowrider)
  239. That kid from Mich w/ the 77 pacecar
  240. 1974 Delta 88 Convert
  241. original wheels
  242. Joe, Newbie really needs your help with Starfire
  243. Structural integrity
  244. Differential swap
  245. First post....
  246. replacing the heater core...
  247. 70 delta 88
  248. '64 Jetstar suspension/brakes/cooling??
  249. parts wanted
  250. 1982-85 Delta 88 Rear Coil Springs
