... transmission question
Old Sep 29, 2009 | 08:17 PM
ShaunM's Avatar
Once again as mentioned before I am not exactly car savvy. I went to get a transmission flush but the dude said he could not do it because there was no cooler hoses. My question is should I get a cooler set up and how should I run it. I have a '56 Hydramatic Automatic transmission.
Thanks again,
Shaun
Old Sep 30, 2009 | 06:11 AM
Shaun, you need to check your radiator to see if it has a transmission coolet. It might not since it is older.
Look at your radiator and see if there are two lines going into the side or bottom of it that come from the transmission. The service guy you talked to may have been an idiot and didn't want to do the transmission flush. Especially if your car has solid lines for the transmission cooler. If your car doesn't have a transmission cooler then that is fine. If it shifts properly then why worry about it?
You could always buy a transmission filter and pan gasket and change the fluid yourself. It is easy to do, especially if you are handy with tools.
jensenracing77
Ninety-Eight
Feb 28, 2009 09:13 AM
svt412
Jul 4, 2008 03:37 PM
whizkid88
Jul 1, 2008 07:13 PM
Olds64
Dec 20, 2007 05:10 AM
Cuttyon22s
Jul 10, 2006 11:24 PM
