View Full Version : Eighty-Eight
Pages :
5]
- ISO '74 Delta grille
- Rocket 88 Heater
- Corroded Freeze Plug '63 394
- Front motor mount, 56 Olds
- '57 Factory Assembly manual
- Stickers missing??
- Rims for Oldsmobile Delta 88 1984
- Wanted parts for a 1964 jetstar 88
- 55 power brake dipstick
- Vinyl top, rear speaker, and rust question
- Need a 63 Super 88 rear bumper - what are my options?
- are 84 deltas impossible to get body parts for?
- 1955 holiday trunk trim
- 59 S88 exhaust exchange: Dual for Single?
- 59 S88 Lubricants and fluids Questions
- I'm on the hunt...
- For want of a nail ...
- Bought a 1977 Delta 88 4dr, 350, turbo 350 trans
- suspensions on 73 delta 88
- '73 Delta88 mirror part number
- info on a 57 88 J2 two door hardtop
- Re: Answer to How much do you know
- 1975 Delta 88 Droptop on Price is Right
- How much do you know?
- 66 oldsmobile 98 trunk latch picture wanted for vacuum relase
- fuel pump
- Leaking Fuel Neck
- kind of gas on '73 350 engine
- Looking for a true carburetor specialist in Minneapolis/ St Paul area
- strange engine bucking on 64 88
- Wiper switch part# for '75 Delta 88 Royal????
- '58 88 VIN Tag Location?
- gas tank
- Headlamp Adjuster clip
- 67 Delmont 88 Convertible Interior Material
- scissor top manual
- WTB - 78 D88 - Tail Light Trim
- 1978 88 Royale ?
- 1987 delta 88 bucket seat conversion
- looking for parts suppliers
- im looking for a 73 or 75 to 79 delta 88
- 1956 olds engine & trans rebuild cost?
- 1956 oldsmobile motor mounts info needed
- 65 delta 88 rear bumper
- brake rotor UPDATE FOR 69/70
- 1979 olds delta 88 royale
- Assembly Manual
- WIW 1957 98 4dr ht
- 1970 Delta 88 Convertible
- My 1967 Delmont 88 traditional lowrider build
- shock options 64 super 88
- minimize my sway
- good used running bolt in v8
- upgrading my J88 brakes
- wifes new 1964 jetstar 88!
- Fuel Tank
- Convertible top..issue.. 1968 delmont 88
- Got an oil leak.. need advise
- sold my 88
- Finnally got the time
- Pics Of My '67 Delta!
- 62 super 88
- noob question '84 delta
- 83 olds 307
- help me unmut my 62 dynamic 88
- Wedding Escort 88
- conv top
- 57 bumpers all the same?
- '58 Super 88 technical questions.
- 1959 Super 88 Converibles
- Some history on my '61 Dynamic 88
- Potential rotors for 65'-70' 88/98 disc brakes
- 1962 Dynamic 394 V8 4 barrel Rochester with a slim jim
- will a 75 cutlass steering wheel fit a 73 delta 88 royale?
- new guy looking for sheetmetal
- Need wheel help
- '67 Delta Rear Sway Bar?
- seeking 78 delta aluminum hood info
- How to change Charcoal Canister Filter ...?
- 1961 88 -98 body mounts
- Water leak issue driving me crazy!
- Bumper Differences?
- delta 88 80-84 hub cap key
- 1984 delta 88 vacuum lines
- Radio removal/replace 1973 88 Conv
- 69 delta 88 custom
- Qjet Rebuild help
- Need help popping out a shock absorber
- I need help with my convertible top! - 75 Delta 88
- Hey, redoldsman! We finally did it!
- 64 super 88 door window issues
- windshield install ??
- 54 Super 88 Glass Windshield Washer Jar and Pump
- 54 Olds Super 88 Hardtop Coupe
- 54 88 Cowl Tag help
- front bumper 69 delta 88 conv
- Engine rebuild
- I think the Super 88 was a stolen car
- check out what I bought
- How long is a 1964 super 88 4 door
- Header Gasket leaking - desperate ---
- Best way to run dual exhaust on stock manifolds
- 63 resto - tranny service
- Need Help ASAP With Window Sweeps!!!
- Parking brake won't release - 1975 Delta 88
- checking my ignition coil - resistance values?
- Need some information on a 1955 88 2 door convertible. please help
- HELP with engine rebuild
- Need a Valance for a '73 DELTA
- how many were produced
- Wheel Size Interchange?
- door panels/interior rear q panels for 73 delta 88 royale
- Anyone see Overhaulin' Tuesday night?
- 1973 delta 88 headers change without engineg lifting?
- 1968 oldmobile Delmont 88 convertible.. couple of questions..
- New-to-me wheels... 1968 Delta
- 1969 olds 88-98 fenders, hood.
- Nut for front wheel bearing
- Eyesore 1975 Royale
- Could Wheelie Use Some Help
- Rear Bumper Repaired! (finally)
- 85 Header Panel
- 1979 Oldsmobile Delta 88 Royale Coupe
- ID/Name
- Looking for Exhaust for '67 Delta!
- 1976 Delta 88 Royale - I like !
- Carbuerator Swap-425 engine
- Last Time I'll ask..DO 63 /88 fenders fit a 64??
- How much of this vacuum crap can I lose?
- Can choke pull off be adjusted?
- 1980-1985 Oldsmobile delta 88 and regency 98 owners
- '64 D88 - Easiest way to R&R fuel pump?
- exhaust manifold needed
- Reverse switch location '85 Delta
- Wiring up a new voltage regulator on my '63
- 1973 delta 88 & 98 interchange?
- 1977-79 Rocker Panel Trim Needed
- What Size Rims and Tires
- Front Structural Pieces
- Lowering my Super
- Hood Trim '63 Super?
- Glue for my hood liner or no?
- Backspace for original 1966 88 rims?
- What is the trick on dropping the tank?
- The unfortunate end of my delta 88 :(
- Started the 98 and 88
- Bet ya never seen one !
- '63 Super 88 - Rebuild a NIB Fuel Pump?
- My 88 co-pilot
- Reverse light switch on 85 Delta
- Radiator Options?
- Unusual request
- Looking for Delta 88 Fender Emblems (1975-ish)
- decisions, decisions, decisions
- 1973 Delta 88 "Dog-House"
- Nice '65 Dynamic 88 4-dr in Lincoln, NE salvage yard
- glass instalation
- 1956 olds door progression
- 1956 olds autronic eye...back again
- 1956 olds door upper door trim ???
- Rear Ended!
- My 79 delta 88 royale
- Air cleaner color
- Interchange for a 62 Dynamic Turn Signal Cancel Cam
- 1962 Dynamic Turn Signal Cancel Cam
- Parting Out- 59 OLD'S 88 4-door H/T
- Have a question and NEED HELP! spindles thread
- 1956 olds tar coating???
- Steering wheel removal
- non old olds related question
- convertible top
- thanks
- 1956 olds trunk lock emblem?
- New '61
- 425 V8 Miles per gallon?
- 1956 olds disk brake rims??
- 1956 oldsmobile hood help needed
- Headliner way too short
- Possible Dynamic 88 for sale
- Poor interior heat in '56 olds
- 1965 Delta 88 gas tank capacity
- 70 OLDS Delta 88
- 67 Delta 88 with 425
- 1966 88 Sheet Metal Question
- 1956 oldsmobile dash knob help
- Looking for a 1965 Delta 88 Coupe
- 1965 Oldsmobile Delta 88 - rare colour scheme?
- Help needed with steering wheel
- 56 Olds wiring help
- Looking for 56 Olds 88 2 door sedan trim
- 71-75 full size gas tanks??????
- 62 wiring harness
- 1970 Oldsmobile delta 88 (with front rotors)
- Broken turn signal on a 62 Dynamic
- oil change on a 1962 Dynamic 88
- Trunk leak FOUND!! More questions arise
- '77 '88' Pace Car at B-J next week
- 64 88 throttle and Convertible questions
- rear window metal trim 74' coupe
- 88's
- frame swap
- Water on passenger side floor
- Wiper Motor
- Vin...Whats the color ?
- Power seat
- 455 in a 1955
- 1974 delta 88 tail lights
- Steering column
- oil pressure guage
- Parts needed
- Do 63 dynamic front fenders fit a 64
- Junkyard Parts Donor Spotted In Southern California
- Trunk leak, but where????
- Fuel delivery
- Twine under trunk seal?
- 62 Dynamic 88 grill emblem?
- Battery tray needed for 54-56 Olds
- cooling system
- 1966 Delta88 - dismantling heater core
- parts interchange
- Original colors
- filler neck install.....
- serial # on Canadian cars
- Need a little help-Headlight switch
- B Bodies 3 on the tree
- radiator replacement
- Decode this '64 dynamic 88 cowl tag
- 67 delmont with red inner fender's?
- Any 371, 394, experts ????????
- Exhaust Extension/ Deflector with Olds logo
- whats up with the convertible scissors ...
- dashboard blue lenses
- 1956 olds hood help needed
- eBay 57 Olds 88
- 78 delta royale interior upgrade
- Batwing air cleaner dimensions
- 63 Dynamic 88 fuel line
- Dashboard -57
- 1956 oldsmobile rims help
- 1964 4 Speed Jetstar Convert L2
- 77-79 delta rear window trim
- 1956 olds front end
- adding delay wiper question
- Just bought an 1982 Delta 88 coupe
- adding cruise control
- 62 Dynamic 88 Conv
- 71 Delta 88 Convertible Steering Wheel
- 1962 Olds Dynamic 88 water pump #
- What do you guys think?
- A long time...
