exhaust manifold needed
Old Apr 18, 2013 | 11:42 AM
KMMONDA's Avatar
Greetings, My 68 delmont is in need of a driver's side exhaust manifold, single exhaust 455 low comp, with built in heat riser. Any suggestions for a source is appreciated. kmmonda
Old Apr 18, 2013 | 01:05 PM
65B01Delta's Avatar
I have one on a 68 455 that I pulled out 2 yrs ago, I'll go take a look at it & get back to you.
Old Apr 18, 2013 | 01:26 PM
65B01Delta's Avatar
Exhaust manifold wanted
Is this what your looking for ? It's on a 68 455 I pulled out of a 1968 Delta Custom.
Old Apr 18, 2013 | 05:28 PM
KMMONDA's Avatar
Thanks, That the right number, it should have the place for the heat riser molded into the exit. I think you've done it . No visible cracks, that's what I'm looking for. Give me some particulars.
Ken Monda
Babylon, NY 11702
Old Apr 18, 2013 | 06:15 PM
65B01Delta's Avatar
$25, you cover the shipping... I'll pull it off tomorrow and look it over real good and we'll go from there. The engine has been in my garage since pulled, so out of the weather.
Old Apr 19, 2013 | 06:41 AM
KMMONDA's Avatar
That sounds reasonable to me. However you would like payment is fine and while you're at it if the other side is good I should probably take the pair, but I definitely need the left bank manifold.
Old Apr 20, 2013 | 06:56 PM
65B01Delta's Avatar
I have both exhaust manifolds unbolted. tomorrow I will remove them. I have to raise the engine because the crossover pipe is still attached to both of them. Will send pictures tomorrow.
Old Apr 21, 2013 | 07:11 AM
KMMONDA's Avatar
65B01Delta: Appreciate the effort, I'm not on any time schedule, don't have to kill yourself. Be nice if it warmed up abit here must be the same where you're at. Picture would be great.
Ken Monda
Old Apr 22, 2013 | 05:31 PM
65B01Delta's Avatar
I have the exhaust manifolds off, PM me with your email address & I'll send a few pictures.
Old Apr 23, 2013 | 06:53 AM
KMMONDA's Avatar
kmmonda@yahoo.com 631-321-8171
atkinsom
May 29, 2013 06:39 PM
lucky strike
Apr 28, 2010 08:02 AM
lucky strike
Apr 25, 2010 08:35 AM
bullet1
Sep 3, 2009 07:28 AM
