Radio removal/replace 1973 88 Conv
Old Jul 15, 2013 | 03:11 PM
chuckcal's Avatar
I was able to get the radio out, but, it wasn't pretty, there has to be an easier way.
The rear brace and the brace on the side that connect to dash panel are were difficult to get at. Is it supposed to all come out together?
I couldn't find any R/R instruction online, any pointers are appreciated.
Old Jul 15, 2013 | 04:08 PM
All you do is remove the four screws that hold the radio cluster face to the dash pad, pop down the two flood lights and the map light for clearance, and pull it out.
If there's still a rear brace, you remove the lower dash panel that runs from the steering column over to the glove compartment, and then it's easy to reach everything up there.
Ease of access for repairs was one of the features they advertised for the new modular dashboards in '71.
As far as I know, all of the instructions are pretty clear in the Chassis Service Manual.
Old Jul 15, 2013 | 06:16 PM
jaunty75's Avatar
I replaced the radio on my '73 Custom Cruiser. You have to remove the lower trim panel on the right side of the steering column, as Eric mentioned, and then everything is easy to get at as far as the radio and everything else under there goes.
I don't know of any other way to get it out. How did you get it out if you didn't remove the lower trim panel?
Old Jul 17, 2013 | 04:54 AM
chuckcal's Avatar
I didn't realize the radio would come out with the cluster, so I twisted the cluster enough to unscrew the side brace, was worried about breaking the plastic. Went in much easier with more of the lower trim panel unscrewed.
Thanks everyone.
Old Jul 17, 2013 | 06:12 AM
Glad you got it fixed!
jaunty75
Vista Cruiser & Wagons
Oct 4, 2014 05:21 PM
kevinalex
Jun 15, 2012 03:43 PM
Finn5033
May 24, 2012 09:36 AM
kevinalex
May 12, 2012 06:20 AM
1969w3155
Jul 19, 2010 09:35 AM
