1974 delta 88 tail lights
Old Dec 31, 2012 | 07:00 PM
carnell71075's Avatar
I am looking for some tail lights for a 1974 delta 88. Any help would be appreciated.
Old Jan 13, 2013 | 03:35 PM
lester79's Avatar
Hello, i might be able to help. How many years will interchange? I live close Romines Used Auto Parts Dandridge,tn. He had a delta 88 there, not sure of year. I believe It was between 73 to 75?
Old Jan 13, 2013 | 08:22 PM
jaunty75's Avatar
The '73s will not interchange at all as those were horizontal in shape:
The '74s and '75s were more squared off. While they are different in appearance, I have heard that the '74 and '75 Delta 88 taillights will interchange if you change out the entire rear fender extension. Of course, then you might have to repaint the fender extension to match the color of your car.
Here's a '74 Delta 88 while below it is a '75. Note the '74 has the horizontal trim piece the color of the car running through the middle of the taillight while the '75 is more one-piece with just an Oldsmobile emblem in the center.
If you don't care that they're not correct in appearance, as I said, I think those from a '75 will fit your '74. I think those from a '76 would work, too, if the '75s will as the '75 and '76 taillights look identical.
Old Jan 15, 2013 | 09:12 AM
I need the 1974 ones. I need to replace the right one. Thanks a lot. Any help would be greatly appreciated.
radioburningchrome
May 2, 2021 07:08 AM
carnell71075
Apr 12, 2015 04:09 PM
Oldssupreme
Apr 3, 2015 08:36 PM
carnell71075
Aug 10, 2013 08:16 PM
carnell71075
Dec 31, 2012 07:05 PM
