frame swap
Old Jan 10, 2013 | 03:50 PM
rr480's Avatar
64/63 olds frame swap
does anyone know if the frame from a 64 olds Starfire will fit under a 63 olds dynamic 88 2 door
Old Jan 11, 2013 | 05:42 PM
copper128's Avatar
Lt. Buzzkill (ret.)
Well, the basic specs are the same (wheel base, track width, etc.) so it seems likely, but I can't confirm it - don't have the part numbers.
Old Jan 11, 2013 | 06:55 PM
rr480's Avatar
I have a 63 olds convertible with a good body and excellent interior with rust issues on the front inside of the frame rails, I have found a 64 olds Starfire convertible the body and floor are totally rusted out but the frame is in good condition, so I was thinking about trading out the frame instead of trying to repairing the 63 olds 88 frame , I don't have any part numbers to go by
Old Jan 12, 2013 | 01:15 PM
Dean Eechaute's Avatar
As long as you go convertible to convertible frames they should swap with no issues. The hard top frames are not boxed in and not strong enough for a convertible. Any other useful convertible or interior pieces good on the Starfire you don't plan on using? Dean
Old Jan 16, 2013 | 06:39 PM
rr480's Avatar
I will let you know after I inspect it further, the interior and floor, trunk pans are pretty well shot a tree fell on the top and it sat for a long time on the weather
oldsmobilty
Sep 27, 2012 04:26 PM
sixty9olds
Jun 14, 2011 06:43 PM
1969goatman
Aug 30, 2010 07:44 PM
DJMatthews
Dec 5, 2006 01:28 PM
