delta 88 80-84 hub cap key
I posted in classifieds also, but thought this might real more delta 88 owners. Does anyone have a key to fit locking hub caps from the above years, that they would want to salw. I found a nice set today at junk yard, but couldn't find the key. Thanks
key
there were different types,is it a bolt or a nut? I may have a set with keys but I still think there should be a code somewhere,do you have te parts that go on the wheel under the lug nuts?
http://www.ebay.com/itm/1982-OLDS-DE...6a51a7&vxp=mtr
I believe this is the key I would need, but dont want to pay 50 bucks for it. Thanks
key
you can imagine that even tho that looks like the right style key it may not work on the locks that are on the car,i've seen junkyards that had a tool kit that could take any of those off .if I might have some that style and if I can find them I will pm you,jim
Thank you
key
after looking at your pic with a magnifying glass I realized the type of key you saw on ebay isn't the right style.i believe I can see a letter on the end of the lock,maybe you could steel wool or sand it to reveal the letter.i have 3 or 4 keys of the style I believe you need.i have also removed that style with a screw driver if they aren't on too tight.
86ChebbyWagon307
Jul 5, 2011 07:09 PM
JMW803
May 13, 2010 04:43 PM
