delta 88 80-84 hub cap key
Old Jul 17, 2013 | 12:25 PM
ramblinwreck's Avatar
I posted in classifieds also, but thought this might real more delta 88 owners. Does anyone have a key to fit locking hub caps from the above years, that they would want to salw. I found a nice set today at junk yard, but couldn't find the key. Thanks
Old Jul 17, 2013 | 01:00 PM
jcdynamic88's Avatar
key
the bolt the key fits on should have a letter stamped on it,there are a few different ones.i have some keys,let me know the code,jim
Old Jul 17, 2013 | 01:06 PM
I looked at each one, and could not find any labeling. It just had splines all around the outer diameter
Old Jul 17, 2013 | 01:33 PM
key
there were different types,is it a bolt or a nut? I may have a set with keys but I still think there should be a code somewhere,do you have te parts that go on the wheel under the lug nuts?
Old Jul 17, 2013 | 01:47 PM
Old Jul 17, 2013 | 01:48 PM
i tried to insert a picture i took today. I hoped it worked. I assume all the hardware was there as they were mounted on the vehicle at the yard and would not come off. thanks
Old Jul 17, 2013 | 04:00 PM
key
I can't identitfy that part in the picture,you might try a left handed drill bit to extract them and then replace them with other bolts.
Old Jul 17, 2013 | 04:11 PM
http://www.ebay.com/itm/1982-OLDS-DE...6a51a7&vxp=mtr
I believe this is the key I would need, but dont want to pay 50 bucks for it. Thanks
Old Jul 17, 2013 | 05:50 PM
key
you can imagine that even tho that looks like the right style key it may not work on the locks that are on the car,i've seen junkyards that had a tool kit that could take any of those off .if I might have some that style and if I can find them I will pm you,jim
Old Jul 17, 2013 | 06:24 PM
Thank you
Old Jul 17, 2013 | 06:32 PM
RetroRanger's Avatar
72 Olds CS
did you check in the car ? alot of times I find the stuff like that in the ashtray, glovebox, trunk, console, over the visor, on the floor you get the idea !!!
Old Jul 17, 2013 | 06:35 PM
I searched pretty good. I didn't check ash tray or above sun visors. Im gonna go back soon for a few things I couldn't get today. I'll check those spots then
Old Jul 17, 2013 | 07:15 PM
Professur's Avatar
Get one of those GatorGrip crap sockets from Walmart .. that'll zip if off right quick
Old Jul 17, 2013 | 07:29 PM
I've never used one, but that might just work. Thanks
Old Jul 18, 2013 | 05:57 PM
ThePackRat's Avatar
Big Daddy No Bucks
Perhaps someone else wants them & is (1) step ahead of you.
(took the key w/the intent of coming back for the covers)
Old Jul 18, 2013 | 06:21 PM
Could be. Could be. Knowing my luck, for sure
Old Jul 22, 2013 | 07:17 AM
key
after looking at your pic with a magnifying glass I realized the type of key you saw on ebay isn't the right style.i believe I can see a letter on the end of the lock,maybe you could steel wool or sand it to reveal the letter.i have 3 or 4 keys of the style I believe you need.i have also removed that style with a screw driver if they aren't on too tight.
Old Jul 22, 2013 | 07:38 AM
Thanks. I tried to answer with pm, but not sure if it worked, I am viewing from phone at work. Let me know if you recieved my reply. Thanks again
Old Jul 28, 2013 | 02:55 PM
DeltaDevil88's Avatar
Get those caps off yet?
Old Jul 28, 2013 | 07:33 PM
3 of the 4 have been removed with help from forum member. I will get the other one if its still there. Rest of the real world taking priority over piddling with the old car
philjr
Feb 24, 2015 03:15 AM
ramblinwreck
Jul 18, 2013 03:10 AM
86ChebbyWagon307
Jul 5, 2011 07:09 PM
guy.graziano
May 5, 2008 07:25 PM
