1966 Delta88 - dismantling heater core
Old Dec 17, 2012 | 11:53 PM
delta88_frankfurt's Avatar
Hi everybody,
the leaking heater in my 1966 88 needs an exchange.
I have the manual, so I know where is what basically.
But if anyone has done it before on an assembled car, I would
appreciate any good advice, step by step tips and tricks to avoid taking unnecessary things apart.
Thanks in advance and season's greetings,
André
Old Dec 18, 2012 | 05:19 AM
radioburningchrome's Avatar
Do you have AC or just standard heat?
If you have AC, remove the duct work on the right side behind the glove box.
Next, I would remove the nuts holding the heater assembly under the hood.
You have will have to alternate between under the hood and in the passenger compartment until all parts are disassembled.
On cars without AC, you will have to get you hands under the right fender to get the last bolt next to the blower fan.
Good luck.
Old Dec 18, 2012 | 05:26 AM
Oldsmaniac's Avatar
As said remove AC ductwork from under dash. Heater core/box assembly comes out from under the dash. There are cables and vacuum lines. Make sure you dont pinch a vacuum line when re-installing. Hopefully insulation pad will stay intact for a good seal against firewall.
Old Dec 18, 2012 | 05:31 AM
Originally Posted by radioburningchrome
... remove the duct work on the right side behind the glove box.
You'll also need to remove the dog.
Old Dec 18, 2012 | 06:41 AM
Thanks for all your answers, and sorry radioburningchrome - yes, with AC.
That means you can reach everything you need without removing the dashboard itself, plus gauges, panels, glovebox etc.?
Everything works from underneath on the passenger side?
...if the dog will be so kind.
Old Dec 18, 2012 | 01:45 PM
One thing I forgot to mention was mark the vacuum lines if so desired. Makes reinstallation a bit less confusing.
71rocket
Feb 25, 2015 03:34 AM
akins2000
Jan 22, 2012 12:39 PM
2blu442
Nov 28, 2008 08:30 AM
cincyDelta
Jun 24, 2008 10:57 AM
EdsDelta
Jul 22, 2004 11:46 AM
