Engine rebuild
Old Jun 10, 2013 | 03:19 PM
BStone's Avatar
Engine rebuild
OK so I picked up a spare 425 out of a 66 Delta. Was running when the guy took it out and put it in his garage. Still got oil in it etc
I was thinking its always good to have a spare and also, it gives me something to play with/learn with without having to take the beast off the road.
The engine is all dead stock and complete less the exhaust manifolds. Its a 2 barrel
I am not looking to dump a huge heap of cash into it and the reality is that I am not experienced in rebuilding motors from the bottom up (have done some motorcycles but that's about it!)
So, my question to you guys is what would you do to this motor?
I am thinking a Q-Jet set-up for starters and ????
Thanks!
Old Jun 10, 2013 | 04:11 PM
And ???? Even though you don't have much experience, it doesn't mean you should cut corners. Save your money and do it right.
Old Jun 10, 2013 | 04:39 PM
Erinyes's Avatar
Depends on what your plans are. At a guess, you're using it for a learning experience, with no fixed time schedule. If so, disassemble it and see what needs to be done!
You might play with rebuilding it for the next three years, picking up parts here and there, without ever dumping a huge amount of cash into it at any one time.
Once you know what machining must be done, then you can start making more solid plans for fun stuff!
Old Jun 11, 2013 | 07:30 PM
firefrost gold's Avatar
Erinyes I liked your post I would add there are some Canada guys on here and that im sure with little begging would and could help out with your build .
Old Jun 11, 2013 | 11:10 PM
BStone's Avatar
I am thinking of converting it to a 4 barrel, cleaning it up and checking overall condition etc.
Is there much benefit to performance cams for example?
I am in Edmonton if there are any local gear heads!
Old Jun 13, 2013 | 01:00 PM
BStone's Avatar
As a follow-on question...
The engine in my car (67) has
397357 - intake
395548 - heads (c)
The spare (66) has
391136 - intake
389395 - heads (B)
All things equal, is either engine better for rebuilding than the other?
Thanks again fellas
jensenracing77
Jan 12, 2016 02:02 PM
805cut
May 3, 2012 08:11 PM
442dreamer
Aug 23, 2011 07:28 AM
Gary's 2 442-S
Aug 14, 2011 12:04 PM
442oldslawyer
Apr 29, 2010 09:22 PM
