Lowering my Super
Old Apr 9, 2013 | 06:42 AM
pbob42's Avatar
Member
Lowering my Super
Things are looking pretty nice on resurrecting my '63. Like to lower it a tad. Any suggestions? Just cut the springs? Running stock wheels at the moment.
Old Apr 10, 2013 | 02:53 PM
Tedd Thompson's Avatar
It will ride like crap if you torch the springs, why don't you go to 50 or 60 series tires. You won't look slamed but you will pull it down a tad and your suspension will thank you....Tedd
Old Apr 10, 2013 | 05:55 PM
copper128's Avatar
Lt. Buzzkill (ret.)
Take a look here: https://classicoldsmobile.com/forums...ngs-found.html
Old Apr 11, 2013 | 07:08 AM
Theo's '67's Avatar
I have been faced with the same question on my '67 Delta 88 as well. Any help anyone can provide for me.
Old Apr 11, 2013 | 08:16 AM
J-(Chicago)'s Avatar
Seasoned beater pilot.
http://classiccarsprings.com/coil-sp...fications.html
I have a pair of rear CC501s here if they'll help. Should fit the full size 67' for theo
I have no idea what the lil 63' unibody cars used for springs though.
Old Apr 11, 2013 | 08:26 AM
gearheads78's Avatar
car guy
Don't torch them use a cut off wheel. Don't cut too much at once. I usually cut about 1/2 coil at a time put it together drive around the block and repeat if needed.
Old Apr 11, 2013 | 08:42 AM
Theo's '67's Avatar
On the CC501 what would the drop height be?
Old Apr 11, 2013 | 09:33 AM
I dont know.....thats why i posted the chart for you. I have no idea whats in your car right now.
Old Apr 11, 2013 | 11:08 AM
copper128's Avatar
Lt. Buzzkill (ret.)
I have the CC503 in the rear of my 67 Delmont (Moog recommended stock replacement) and if anything it rides above stock ride height. From the chart, it looks like the CC501 would lower the car at least 2" (compared to the 503). The spring rate is roughly the same, but the free height is 3-3/4" less.
Dunno if that helps you at all, but it's difficult to be absolutely certain what the exact ride height will be with any given spring going strictly by the specs.
Old Apr 11, 2013 | 11:32 AM
This doesn't work on coils with double pigtail ends like a 67' Full size
Old May 18, 2013 | 07:34 AM
KQQLCAT's Avatar
I cut one full coil out of the front in my 61 and it lowered it 2". The ride did not change much at all. I would try that before buying springs and do not use a torch use a cut off wheel. I did not need to cut the back because the old springs sagged just enough to allow the stance I wanted. You can't cut the back ones because of the taper in them. If you don't like it after your done your done you can always buy new ones and if you do your not out any money.
giaguaro
Suspension & Handling
Jun 10, 2013 09:57 AM
62HOLIDAY
Dec 8, 2010 05:24 PM
eddiem06
Dec 24, 2006 08:06 PM
lestat4speed
Sep 11, 2006 04:13 PM
SuperSickBoy
Jun 8, 2006 12:53 PM
