View Full Version : Eighty-Eight
Pages :
4]
- Looking for Seat Belt cover
- 64 Dynamic 4 door with a 394 and... Buckets and console??
- 307ci to 407cid engineswap in 1979 delta 88
- New heater core leaking?
- 1956 Olds 88 build part 1. Back to yesteryear.
- Rear seat belts
- 52 Oil Canister Disassembly
- Help with 1964 VIN decode
- Dry Ice Blasting car parts...
- 1968 Delmont 88
- Batwing
- 74 88 water pump install ???
- Can a water pump be rebuilt?
- Brought home my new 1976 Delta 88 Royale Coupe
- 1974 88, what is box under pass seat
- How rare are the Pace car 77/78 88's??
- 1964 olds dynamic 88 suspension parts help
- 78 royale interior upgrade finally finished!
- 1974 Convert Top Question
- 1974 88 tech questions, this and that
- windshield and back window
- 1974 Delta 88 heater core needs replaced, ???
- 1978 Delta 88 Royale in storage
- Belt reveal mouldings 77-79 Olds Delta 88
- got my eye on a 69 Delta 88 455
- Just bought a 67 Delmont
- Header and exhaust options
- 1967 Delmont 88 production numbers
- it was horrible... 65 88
- 1977 Oldsmobile Delta 88 in junkyard
- Rocket 88 trunk emblem location
- Window track
- Research for 9C1 rear install on 78-85 Delta 88
- 56 Olds, install sound,heat barrier
- 1972 88 fuel gauge issue
- 394 exhaust crossover pipe.
- 1979 Oldsmobile Delta 88 Royale Coupe parted :(
- 79 Delta 88 in junkyard
- '67 Delta 88 engine troubles
- cutting coils on 54 88
- Swapping 350 into 88
- busting loose brake lines
- Adding tranny fluid to fuel crazy or not
- Swap steering wheel for 4 spoke..
- Demolition Delta... Unreal...
- anyone ever change a rear seal without pulling the engine?
- 1970 Delta 88 - Will 4 dr trunk lid fit 2 dr car -
- Need help with a Delmont 88 town sedan model
- 62 super 88 overheating
- 1955 super 88 build
- What type ATF?
- Next question, vibration
- Gas gauge becomes increasingly inaccurate as tank is used
- Ignition Rack
- `73 Delta 88 Rear Window installation problem
- Will 1969 Rotors fit 1970 Delta 88
- My Delta 88 has converted me into an Oldsmobiler
- Disc Kit from Street Rod Garage for '55
- 394 vapor locked? How to prevent from happening?
- Advice on nice hubcaps
- early 50's Olds (Lake) Side Pipes
- Door switch plugs
- Power window motor, remove and replace
- Concours judge - looking for a little help
- 394 dies when it gets warm... 64 dynamic 88
- 1966 delta 88 signal light issue
- Starter?
- "Delta 88 Custom Cruiser"
- What part do I need?! Engine mount troubles...
- Cam and Lifters
- My soon to be Delta 88 Brougham, and a couple questions
- Which Jack for '73 88?
- 56 super 88 hood help
- My New to me 88
- Exhaust for 56 olds
- fuel gauge moves 1/4 in time with blinkers
- 64 88 runs out of fuel when going up hill, if under half tank
- 1972 Oldsmobile Delta 88 fuse panel
- Fuel Problem
- 59 Holiday Coupe Quarter Window Question
- 64 super 88 fuel tank leaking from sender?
- '62 Dynamic 88 Reverse threads!!! PLZ Help
- 72 Delta 88 remove back seat to replace drive cable
- Tranny dip stick incorrect readings YIKES
- Problem with turn signal bulb-help!
- 63' super - emblem removal
- New member!
- 64 super 88 fuel line to carb issues
- 1973 delta 88 conv exhaust tailpipe
- outside door handles for 69 delta 88 convertible
- sputters and dies when engine slows
- Our '72 Delta 88, Adventure and update
- Gas Gauge issue
- 79-85 D88's Differences?
- Seat Rails/Tracks 75 delta 88???
- Leak from oil canister - 52 Olds Super
- Too good to be true? Also, lighter?
- Any Delta 88 experts around?
- 64 super 88 finding rear brake hose?
- olds 76 vs 88
- Shim a power steering pump?
- Advice on potential '63 Super 88 Restoration
- any 1968/70 350 powered 88's
- '75 transmission problems
- Random misfire
- I need help quick!!!
- th400 shift shaft seal
- trying to time a 394
- 1955 Olds Super 88 VIN tag and body tag decode
- 51 rocket 88.
- shock absobers for 57 olds?
- New Rotors for 1968 Oldsmobile Delmont 88
- Rough day in the delta 88 today
- clock removal
- 73 Delta 88 windsheild
- Rims & Wheels 70 Delta 88
- BIG Problem with my brakes
- '71 Delta 88 U11 certified speedometer
- 71 drag link
- '67 Delta/Delmont Rear Bumper Rubber?
- suspension diagram
- Floorpan compatibility '71 D88 4D HT
- 1956 oldsmobile
- 80's b body exhaust kits
- 1968 delmont 88 455 throttle response..help
- vendor for rebuilding power steering box?
- 63 dynamic cowl tag info
- saving the delta
- Body Mounts
- What happened to my MPG's?
- My Delta88 history & some info from South Australia...
- 65 Jetstar 88 Converting to power brakes
- name that power brake booster...
- parts i can use from other gm cars
- 1955 88 MotorSwap!
- idler arms
- 1975 delta 88 rear end
- 1955 Super 88 Help Me Save My Trim!!
- How to swap motor mounts 68 Delmont 88 455
- Issue with fuel float in tank
- will 69 parts fit a 70 delta 88
- 1975 delta 88 heating problems
- window felds-sweeps 68 delta custom
- '73 Delta88 Diff Identification blank??
- Top mechs
- 1968 delmont 88 parts sourcing help
- muffler recommendations 56 Olds
- Im buying a 63 super88 parts car
- 63 olds 88 ?s
- Car hesitating going up hills.
- rear shocks 63 S88, any recomendations?
- 69 delta 88 custom wth the B09 package
- 4 core radiator 78 Delta 88
- vin stamp on frame 83 delta
- Right side mirror (pass)
- Eighty-Eight Dash Pad
- carb problems 1950 old 88 303 engine
- 1980-1985 Delta 88 towing capacity
- rear coil springs
- 1962 Dynamic Fuel Pump Rebuild Diagram
- Help Oldsmobile Super88 1961 any data
- heater core replacement 64 super 88 w a/c
- 55 Old 88 sheet metal
- 1963 Oldmobile Rocket 88 - What Can you tell me?
- Loud "ping" when I stepped on the brakes
- no vendors
- 64 jetstar 88
- Advice Please?
- 55 side window removal help needed
- remove speedometer cable
- 4 complete ssIV's
- hood scoop
- What is the horsepower increase when adding dual exhaust
- Slim Jim cooling line info please
- I have some 71 big bolt pattern rally wheels for sale, SSIV's
- Kelsey Hayes Magstars wheels for 70 delta 88
- 1957 WW controls
- help/ advice on fitting window seals needed
- rebuilding fuel pump?s 64 super 88
- Header fitment in a 78 Delta 88
- Santa gave me!
- Now What? 56 jetaway
- Deck Lid Release
- Front motor mount, 56 olds, rest of the story
- ISO '74 Delta grille
- Rocket 88 Heater
- Corroded Freeze Plug '63 394
- Front motor mount, 56 Olds
- '57 Factory Assembly manual
- Stickers missing??
- Rims for Oldsmobile Delta 88 1984
- Wanted parts for a 1964 jetstar 88
- 55 power brake dipstick
- Vinyl top, rear speaker, and rust question
- Need a 63 Super 88 rear bumper - what are my options?
- are 84 deltas impossible to get body parts for?
- 1955 holiday trunk trim
- 59 S88 exhaust exchange: Dual for Single?
- 59 S88 Lubricants and fluids Questions
- I'm on the hunt...
- For want of a nail ...
- Bought a 1977 Delta 88 4dr, 350, turbo 350 trans
- suspensions on 73 delta 88
- '73 Delta88 mirror part number
- info on a 57 88 J2 two door hardtop
- Re: Answer to How much do you know
- 1975 Delta 88 Droptop on Price is Right
- How much do you know?
- 66 oldsmobile 98 trunk latch picture wanted for vacuum relase
- fuel pump
- Leaking Fuel Neck
- kind of gas on '73 350 engine
- Looking for a true carburetor specialist in Minneapolis/ St Paul area
- strange engine bucking on 64 88
- Wiper switch part# for '75 Delta 88 Royal????
- '58 88 VIN Tag Location?
- gas tank
- Headlamp Adjuster clip
- 67 Delmont 88 Convertible Interior Material
- scissor top manual
- WTB - 78 D88 - Tail Light Trim
- 1978 88 Royale ?
- 1987 delta 88 bucket seat conversion
- looking for parts suppliers
- im looking for a 73 or 75 to 79 delta 88
- 1956 olds engine & trans rebuild cost?
- 1956 oldsmobile motor mounts info needed
- 65 delta 88 rear bumper
- brake rotor UPDATE FOR 69/70
- 1979 olds delta 88 royale
- Assembly Manual
- WIW 1957 98 4dr ht
- 1970 Delta 88 Convertible
- My 1967 Delmont 88 traditional lowrider build
- shock options 64 super 88
- minimize my sway
- good used running bolt in v8
- upgrading my J88 brakes
- wifes new 1964 jetstar 88!
- Fuel Tank
- Convertible top..issue.. 1968 delmont 88
- Got an oil leak.. need advise
- sold my 88
- Finnally got the time
- Pics Of My '67 Delta!
- 62 super 88
- noob question '84 delta
- 83 olds 307
- help me unmut my 62 dynamic 88
- Wedding Escort 88
