64 super 88 door window issues
Old Jun 24, 2013 | 07:15 PM
1964super88's Avatar
So my driver door window would only go up or down if i help the window. So i took the panel off, and window out, i found one of the rollers broken on the scissors lift, I added pictures top one shows the broken piece, and second shows the, good other side. It looks like the roller is riveted on. Is there way to just replace just the plastic roller? Maybe the plastic slips on? or do i have to replace the whole scissor lift. Sorry the second picture is a little dark
Old Jun 25, 2013 | 01:31 AM
nsnarsk65cutlass's Avatar
You can get replacement window regulator rollers, but need to grind off the old ones.Best done with regulator removed.
1964super88
May 23, 2014 08:13 AM
sdj
Nov 24, 2013 06:01 AM
bigjaythe1st
Feb 21, 2012 06:45 PM
StarGeneral
Body work
Jan 25, 2012 10:58 AM
FIJIBLUE72
Body work
May 6, 2009 04:58 AM
