Interchangable?
Old Nov 3, 2010 | 01:30 AM
HIGHCOMP425's Avatar
Interchangable?
Parts are getting hard to find. Is there a place that tells what other years will interchange with a 1965 Dynamic 88 vert? Can some one point me in the right direction or have the knowlage? I want to finish the old gal.
Old Nov 3, 2010 | 06:40 AM
Hollanders Interchange Manual:
https://hollanderinterchange.net/cat...2d4bb1c5565943
Old Dec 8, 2010 | 05:45 AM
OLDZGUY's Avatar
The problem with Hollander is it's too vague.
For instance they said all REAR Coil Springs from 1961-66 Olds 88 were the same.
What they didn't mention is the Coil Size (round) and Tension. 1964 lost several humdred pounds so the Obsolete 1963 Springs are heavier...but I found some.
If you want the correct parts and not just "the parts that fit" look elsewhere.
What are you looking for?
I have a 1963 D88 HC and many Parts Books
Old Dec 8, 2010 | 08:54 AM
Thats the impression I got reserching them and was not satisfied.Do not realy need any parts, just wanted to know what interchanges with a 65 Dynamic 88 vert for back up parts.
Old Dec 8, 2010 | 09:55 AM
OLDZGUY's Avatar
Well I'm sure you know the 425ci Engine was from 1965-1967. Here are some Parts Links to keep you busy looking:
http://www.buickpartspage.com/a-zpartslisting.cfm <many links here fo Olds and all cars
http://www.hemmings.com
http://www.fusick.com
http://www.usapartssupply.com
http://www.kanter.com/
Old May 12, 2012 | 10:47 PM
RickyHoliday's Avatar
Hey OLDZGUY,
Would you mind letting me know what breaks interchange with a 63 D88 Holiday Sedan?
If you would...
Thanks!
Old May 13, 2012 | 10:55 AM
Originally Posted by RickyHoliday
Hey OLDZGUY,
If you would...
Thanks!
I think most of the stuff that breaks is the same...
Now, if you mean BRAKES, then the 63-64 Olds full size (except the 1964 Jetstar 88) all interchange. If your real question is what DISK brakes interchange, the answer is nothing easily.
Old May 13, 2012 | 12:17 PM
Thanks, Joe. If I did that every time I had a chance to, I'd be a pariah here.
Old May 13, 2012 | 06:54 PM
Yes brakes. Sorry and Thanks...
Old Jul 2, 2012 | 08:32 AM
Does it go the same for drums? 64 fits a 63? Hollanders says only 59-63...?
Old Jul 2, 2012 | 11:58 AM
chequenman's Avatar
My G.M. Master catalogue says for front drums '64 F/S Olds fits only '64, and '62 / '63 F/S Olds are interchangeable. The '63 Starfire has it's own drum which is a different Number. Hope this helps.
Old Jul 3, 2012 | 10:20 PM
That helps thank you, and it is as i thought... Just hope i can find some cheaper somewhere than the $100 each at Kanter... :/
Old Jul 5, 2012 | 08:15 AM
copper128's Avatar
Lt. Buzzkill (ret.)
I wouldn't much worry about spending a C note on a new brake drum. As collector car prices go, that's not bad. Besides, it's a safety item and if your old ones are out of spec or damaged... what's it worth to be able to avoid an accident just once?
Just sayin'
Old Jan 27, 2013 | 12:39 AM
Forgive a late reply, and thanks yall for all the brake (and break) direction. Got a load of rebuild parts from rockauto.com. Missing one of the front main spring brackets which im sure i can fab unless someone has a better thought... More concerning is the both right and left front spindles. Both are fairly chewed up. Plan on hitting it with a fine file or a die (which would suck finding a right and left handed (not even sure of the size/thread.)) Haven't yet looked for dies, but I have spent a bit getting all the rignt parts from rockauto.com. I also am missing one of the front main spring brackets, which im sure i can fab, unless given better advise.. Really just wondering if a conversion at this point would be a no brainer...?
Old Feb 4, 2013 | 10:01 PM
amesolds's Avatar
You might want to try http://http://www.ctcautoranch.com/index.html in North Texas. I am sure they have the spindles you need, and possibly other items. Good luck!
Bluemeanie
Drivetrain/Differentials
Feb 28, 2013 08:43 PM
antweave
Apr 21, 2011 12:41 PM
tarzangui
Sep 24, 2009 09:58 PM
The_Jeremiah
Oct 3, 2007 06:38 AM
Jhain85
Jul 10, 2007 09:16 AM
