Door seal replacement
Old Aug 19, 2011 | 05:34 PM
BStone's Avatar
OK so ordered some new rubber door seals.
Would appreciate any advice as to how best to replace them and any tricks you guys might have
Old Aug 19, 2011 | 06:18 PM
Lady72nRob71's Avatar
Assuming a 72 Cutlass...
If just around the metal door shell, those are easy. Use 3M WS cement at just the ends.
Aside from the crappy plastic rivets that came with it, the "metro" brand seal is a well-fitting piece!
Buy new quality rivets or reuse your old ones. Most all of the new rivets included with the new seals broke as I tried to push them in...
What car you have?
Old Aug 19, 2011 | 06:20 PM
BStone's Avatar
Oops...sorry, my car is a 67 Delta 88 Coupe!
Old Aug 20, 2011 | 06:14 AM
copper128's Avatar
Lt. Buzzkill (ret.)
Method is the same. Just remove your old seals making sure you get all of the pushclips out, then clean the area thoroughly, wipe it down with solvent (I use lacquer thinner) and let it dry. Install the new seal starting from one end and work your way to the other end. I used 3M black weatherstrip adhesive sparingly along the whole length (apply as you go - it dries fast). Don't close the door until the adhesive is good and set. Then close it and leave it closed for a day or so. If you can get it warm in the sun for a while, that's a good thing.
Occasionally the holes are just too tight for the retainers to push in, especially at the thick ends. I kept a cordless drill handy and slightly reamed a couple of the holes to get the pins in.
1965cutlassragtop
May 8, 2012 01:00 PM
Lady72nRob71
Jun 26, 2011 06:59 AM
drewt
Drivetrain/Differentials
Dec 1, 2009 07:28 AM
jensenracing77
Apr 16, 2009 04:59 AM
Sixoh
Aug 8, 2006 05:11 AM
