68 delta 88 front left wheel spindle question
Old May 3, 2011 | 08:51 PM
CrazedCountryRebel's Avatar
TalksToToads
Someone welded the nut on under the cap on the wheel hub where the speedometer cable goes on my Delta 88. So I guess I need a new spindle and nut. Does anyone know where I can find this? it's in the shop so I can get them to cut it or whatever but I need to find these parts. I found this but it says it is for the other side. http://www.rockauto.com/catalog/x,ca...,parttype,1616
Old May 3, 2011 | 09:01 PM
Welded? Are you sure?
You mean the nut that holds the wheel bearing and the spindle on?
It should be retained by a C-clip.
We need pictures.
Old May 3, 2011 | 09:29 PM
TalksToToads
well I have not actually seen it... My mechanic said somebody welded it.
Old May 3, 2011 | 09:40 PM
TalksToToads
I wonder if something like this would work with modifications http://www.jcwhitney.com/trailer-spi...wx?filterid=j1
Old May 4, 2011 | 02:54 AM
No.
That would be a BAD IDEA.
I'd still like to see exactly what's going on in there before saying anything, but IF somebody really went in and welded the nut onto your spindle, then you need a new spindle.
Old May 4, 2011 | 04:17 AM
B964's Avatar
Looks like you need to salvage yard search. Depending on your area that may be easier said than done.
I miss my days in San Diego when I could go to Brown Field area yards and find 60's and 70's cars there.
Pictures first thou....
Old May 4, 2011 | 05:32 AM
Oldsguy's Avatar
Past Administrator
I agree with MD, you need more information before making a recommendation.
Old May 4, 2011 | 08:31 AM
TalksToToads
Are there any other spindles that will fit? if it has to be from a Delta 88 I'm screwed. He said I need a new spindle, I really don't want to drive over there, jack it up, take the wheel off, take the cap off and take a picture.If I had the car here it would be different. Anyway I understand why you want pictures, but I've been going to this guy for 4 years and I trust his judgment in saying I need a new spindle. There are a few Cutlasses in scrap yards around here any chance that would fit? How about other GM full size cars?
Old May 4, 2011 | 08:39 AM
If the spindle is truly shot, then you need one from a 65-69 B or C body, if you've got disc brakes, or from a 67-70 B or C body if you've got drums.
They're out there. Good luck.
Old May 4, 2011 | 08:52 AM
TalksToToads
I've got the drums, does it have to be an Oldsmobile?
Old May 4, 2011 | 08:55 AM
Dapapadon's Avatar
Give these guys a call, they should have a spindle. 800-995-4999
Remember to get the nut and retainer clip too.
http://www.allamericanclassics.com/
Don
Old May 4, 2011 | 09:54 AM
TalksToToads
Don
Wow, thanks for that link, they actually have stuff for this car unlike everybody else. I'm getting a spindle and a window regulator.
ysgarage.jp
Aug 19, 2015 09:00 AM
Christophe2m6
Oct 7, 2014 02:05 PM
OldsMotion
Nov 25, 2012 07:22 AM
perro
Brakes/Hydraulic Systems
Sep 3, 2007 01:30 PM
