Thermal Switch
Old Jun 12, 2011 | 03:35 PM
Redog's Avatar
Thermal Switch
1985 Delta 88
Thermal switches. There is 2 in the manifold and they each have 2 vacuum lines comming out of them.
What do they do? I forget. I was looking to remove the rear one to put in a water temp sender and the front one to put in a fan switch for an electric fan
Old Jun 13, 2011 | 03:24 PM
Redog's Avatar
Are they carb or emissions related?
Old Jun 13, 2011 | 06:58 PM
Lady72nRob71's Avatar
Emission - one is for charcoal can purge, one for EFE (early fuel evaporation) - the valve at the exhaust manifold that directs exhaust through the intake to heat it up. If you remove the these, make sure the controlled device is disabled. In other words, you need to figure out if vacuum opens or closes the valves.
These diags may help you...
http://members.dandy.net/~k0xp/Oldsm...dsDiagrams.htm
jerseyjoe
Nov 2, 2014 02:22 PM
bornwina
Mar 24, 2013 04:21 PM
Rob delta
Jan 31, 2012 02:43 PM
1973olds98
May 16, 2010 11:56 AM
