Rechroming plastic
Old Aug 28, 2011 | 04:44 PM
BStone's Avatar
Rechroming plastic
What are my options for "rechroming the" plastic bits? Specificall the door pull trim on the inside.
Old Aug 28, 2011 | 06:11 PM
501Paratrooper's Avatar
Check this thread out.
https://classicoldsmobile.com/forums...e-plating.html
Old Aug 28, 2011 | 07:40 PM
66ninetyeightls's Avatar
Land Yacht Captain
Keep in mind this process is generally very expensive so if you can find a reproduction or a replacemnt it will most likely be cheaper.
Old Aug 28, 2011 | 08:51 PM
Funkwagon455's Avatar
Totally depends on the model, sometimes it is easier and more economical. Try a search on this subject, there has been several threads just recently with a great deal of pertinent information that can help you make an educated decision.
Old Aug 28, 2011 | 10:01 PM
BStone's Avatar
Looking for a pair of the front arm rest bases for a 67 Delta 88. Does anyone know if the Delta used the same as other GM cars of the period?
Old Aug 29, 2011 | 06:41 AM
copper128's Avatar
Lt. Buzzkill (ret.)
Yes, they're the same. I bought my reproduction armrest bases and pads from Ames Pontiac (listed for a '66 Bonneville). Much cheaper than having originals rechromed/reupholstered.
Old Aug 30, 2011 | 08:21 PM
BStone's Avatar
These seem to be the correct ones for a 67 Delta
http://www.ebay.ca/itm/65-66-67-Impa...item53dba2c85d
The seller also has them without the pads for cheaper
Old Aug 30, 2011 | 08:33 PM
copper128's Avatar
Lt. Buzzkill (ret.)
Ames sells the set for much less: https://secure.amesperf.com/qilan/De...6&web_access=Y
Edit: The link above is for an incorrect set (front doors of a 4-dr car). You should try calling Ames to be sure of the right part. The Tamraz link you posted does look to be the right one. I know the bases are notched at the front lower corner for the paddle handles. The pads have a notch for the hand pull area also.
Old Aug 30, 2011 | 08:41 PM
oldsguybry's Avatar
NOVICE car nut
with some of the chrome lines on the dash , didnt they use chrome tape?
Old Aug 30, 2011 | 08:53 PM
copper128's Avatar
Lt. Buzzkill (ret.)
OK, after checking a little closer, I believe Ames part #PA286JRE is the whole set with red pads ($99)
#PA256 is just the chrome bases ($53)
Old Aug 31, 2011 | 06:45 AM
Land Yacht Captain
Hmmm... I wonder if there is anything there that would be the same for my car.....
Old Sep 1, 2011 | 01:27 AM
DeltaDevil88's Avatar
On the door pulls on my delta it is chrome tape...they were peeling so i just took them all the way off and kept it moving.
Old Oct 14, 2011 | 12:37 PM
hardtop/ragtop's Avatar
plastic chroming
I had the arm rest bases for my '66 Delta Holiday Coupe rechromed by a fellow out in Wisconsin.
They turned out beautiful. Cost me $ 35.00 each plus shipping.
The turn around time was about 3 months so if you're in a hurry, you may want to explore other options.
If you want the contact info, let me know.
Ron
DreamSupreme71
Aug 25, 2013 04:12 PM
nelsontj
Jun 12, 2013 11:38 AM
AzMotorhead
Apr 21, 2013 07:30 AM
doggonn
Jul 31, 2011 06:50 PM
German442
Body work
Feb 9, 2010 06:37 AM
