front suspension torque specs
Old Nov 18, 2010 | 10:12 AM
D Appeldorn's Avatar
got a question on the torque of the ball joints.
I got to wrench it on a torque of 70 and 40 ft- lbs min.
What is ment with min. minimum?
Or could i just set the torque on 70 ft-lbs on the lower arm, and 40 ft-lbs on the upper arm.
So i do not understand the min. as 70 ft-lbs min.
Old Nov 18, 2010 | 12:12 PM
Run to Rund's Avatar
Take it to 40 and then tighten further until you can get a cotter pin through the stud and castellated nut.
Old Nov 18, 2010 | 12:39 PM
Lady72nRob71's Avatar
Yep! You NEVER loosen a nut to get a cotter pin in.
Old Nov 18, 2010 | 10:28 PM
ok thanks,
i had this in my mind but did'nt understand the " min."
So this meaning "minimum"?
I knew it is was a strange question, but did'nt want to make a mistake with the suspension/ steering parts
thanks
Old Nov 19, 2010 | 05:18 AM
No prob - I remember asking this same question 7 years ago when I was rebuilding my ford's front end.
We all learn things at different time.
dynamic88
Mar 7, 2008 03:32 PM
leslie
Jan 26, 2008 04:06 PM
SX455
Sep 20, 2007 06:47 PM
neoinbiz
Oct 24, 2006 07:42 AM
mcutlass1969
Jul 4, 2006 10:20 AM
