Starfire adjustable sterring column.
Old Mar 26, 2011 | 10:48 AM
Higgins's Avatar
My 1963 Starfire has a non-adjustable steering column. I would like an adustable one but the only ones I can find are coulmn shifts on 88's. Any body know if that would work with the parts from my old one to change it to a floor shift column? Not something I have to have, but would be nice.
Also from what info I can get, only 63 & 64 columns will fit.
Higgins
Old Mar 26, 2011 | 12:54 PM
Oldskeeper's Avatar
hi Higgins,
Yes a tilt column will work if you transfer some of the pieces and do away with the shifter tube, I have done this for a few people over the years.
Steve
Old Mar 26, 2011 | 06:35 PM
rocketraider's Avatar
Oldsdruid
I was also told 63-64 are interchangeable. I tried to put a 63 tilt column in my blue 64 and there was enough difference at the lower bearing area that it would not work.
May have just been my experience. I sold the thing at a considerable loss because I ended up paying for it twice- the absentminded Californian I bought it from forgot to cash the bank check I sent him, and when he remembered to cash it nearly 10 months later, the bank out there wouldn't honor it. More than 180 days since issue.
Should have just told him tuff shushu, but I have always prided myself on doing business honestly and fairly.
Old Mar 27, 2011 | 08:31 AM
Higgins's Avatar
Originally Posted by Oldskeeper
hi Higgins,
Steve
I was also told 63-64 are interchangeable. I tried to put a 63 tilt column in my blue 64 and there was enough difference at the lower bearing area that it would not work..
Thanks for the info.
Higgins
Old Mar 27, 2011 | 09:08 AM
Higgins's Avatar
I really do know how to spell "steering". I just noticed I had two Rs instead of Es.
Old Mar 27, 2011 | 10:03 AM
Oldskeeper's Avatar
I have not tried to change year to year, only changed model and convert column shift to floor shift, I rebuilt a starfire column for a 64 for a friend when his wheel became sloppy and floated around and converted a column shifter to a floor shifter.
When I changed the shifter tilt coulmn to a floor shifter column I machined up a new piece where the shifter lever mounts,you could grind off the mounting flanges and fill the hole with epoxy. I have a lathe so making a new part isn't a big deal.
Steve
Old Mar 27, 2011 | 10:18 AM
Higgins's Avatar
Steve
Since my column is a floor shift non-tilt, would I still have to use the collar off the column shift tilt and weld up the hole or can I use the one off mine with no shift lever? I've never seen a tilt-column up close to see the differences.
Higgins
Old Mar 27, 2011 | 11:11 AM
Oldskeeper's Avatar
I think it should be OK, all my cars are tilt so I have to look at my spare part stach and see if I still have the old part, I purchased a tilt floor shift column from a guy and he sent me a column with a shifter so I just turned up a piece and it worked fine.
I'll look into it later in the week and get back to you
Steve
oldsw31
Jun 21, 2013 05:37 PM
Ceilingman
Oct 2, 2012 01:05 PM
slowolds
Oct 3, 2011 12:29 PM
UnkleMarc455
Jul 11, 2011 10:36 PM
sgibbisdrunk
Apr 24, 2011 08:45 AM
