Converting to quad carb - 67 Delta
Old Sep 12, 2011 | 08:31 PM
BStone's Avatar
Dumb question but is I want to put a 4 barrel on my car instead of a 2 barrel, do I need to change the intake manifold as well as the aircleaner base?
ie is the 4 barrel rockester a direct bolt on less air cleaner base?
Old Sep 12, 2011 | 08:35 PM
Cratethis's Avatar
If it is a 2bbl intake, which it more than likely is, then yes.
Old Sep 12, 2011 | 09:09 PM
mfgusa's Avatar
Registered Thread Killer
confirmed X2
Old Sep 13, 2011 | 06:45 AM
Yes, and yes!!!
Old Sep 13, 2011 | 06:52 AM
rocketraider's Avatar
Oldsdruid
You have to have a 4-barrel intake. You'll also need 4-barrel choke parts ($$$ because of the 442 parts crossover), 4-barrel fuel line and you'll have to adjust the throttle and transmission switch linkage. Then you have to find a 4-barrel CCC aircleaner.
A correct 1967 QuadraJet is side fuel inlet.
If all you want is a 4-barrel, you might be better off just getting an aftermarket aluminum intake, carb and aircleaner and save the CCC stuff for when it counts. You'll still have to set up the transmission switch to keep your switch-pitch working properly and not grinding itself up.
rallyedave
Jul 2, 2014 05:02 AM
72cuttys
Oct 14, 2013 09:30 AM
BStone
16
Aug 12, 2011 10:17 AM
eddieunderground
Aug 14, 2010 04:35 AM
olds4life
Jul 3, 2009 12:08 PM
