'67 Delta 88 pwr window motor needed!
Old Aug 20, 2012 | 12:36 PM
ent72olds's Avatar
Registered Luser
Arrow '67 Delta 88 pwr window motor needed!
Yes, a passenger side from a 2 dr if it makes a difference. I posted a wanted ad! Please let me know what you have. Thanks! The qtr window is the same. Part # 5045238 or 5045191.
Old Aug 20, 2012 | 01:40 PM
copper128's Avatar
Lt. Buzzkill (ret.)
Eric, if all you need is the motor (#5045589), it can come from the RH side of almost any Cutlass through 72.
Old Aug 20, 2012 | 02:50 PM
ent72olds's Avatar
Registered Luser
Excellent! Thanks Glenn. The part # on mine is 4907191 on the inside when the gear is removed. On the outside of the same motor is 5045191.
Old Aug 20, 2012 | 03:00 PM
ent72olds's Avatar
Registered Luser
Ttt
Old Aug 26, 2012 | 09:27 PM
ent72olds's Avatar
Registered Luser
No longer need...bought a set from RockAuto.
Curts1970cutlass
Brakes/Hydraulic Systems
Mar 8, 2013 06:59 AM
ent72olds
Aug 28, 2012 03:01 PM
ent72olds
Aug 26, 2012 09:24 PM
68ragtop
Apr 19, 2008 09:45 PM
1BAD68"S"
Nov 30, 2006 10:20 PM
