erratic running under load
I have tried to find the source of my erratic running "56 Olds by doing all the usual common electrical replacement/repairs (points,plugs, coil, condensers, re-built the carb and had the timing checked (dead on). I feel that one issue might be connected to the methanol/gas that may have caused the current problem. At this point, short of filling with non-ethanol gas and/or using an additive, I,m stuck for an answer or where/what to try next. Motor is all original (as is the car) with 61 K. Need help !!
Thanks, Larry
Thanks, Larry
You may be right about the ethanol gumming up the situation. Fuel pump original or a replacement? Fuel filter? Vacuum leak? Spray some carb cleaner around the base of the carb, vacuum ports and listen for engine to rev up slightly. Oh and welcome to the CO. You may choose to start a newbie thread to introduce yourself, tell us about your rides and post pics of what sounds like a neat '56 Olds.
Scot
Scot
I have found Lucas fuel treatment to help with gummed up carbs.
The methanol fuels of today have their inherent problems, expecially with moisture, loosening up junk in fuel systems, and raising hell with rubber parts!
Good luck!
Good luck!
I have found the following:
1. Only buy gas from name brand stations for your classic. CItgo, Safeway, Costco, etc, gas has caused me problems several times. when I buy from Shell, Chevron, etc, I never have problems
2. Keep fresh gas in your car. The blended fuels deteriorate is a short period of time
3. If you must store without using then use a fuel stabilizer
Just my two cents
Just my two cents
Thanks everyone for your suggestions. I'll check those areas that was suggested. I filled the tank yesterday with non-ethonal gas and added the prescribed four ounces of an oil additive. Friend of mine, with a corvette and camero, uses this oil in his cars and though it is pricey, he swears by it. I'm hoping it will help. Got caught in a huge rain storm yesterday so didn't have much chance to run it in. We'll see !
You haven't mentioned your fuel pump have you checked it?
A quick test can be done by putting a rubber hose on the outlet side of the pump and with the coil wire removed crank it over for about 10 seconds, should fill a 16oz coke bottle 3/4 of the way .Just a thought...Tedd
PS. Welcome to CO. Love the 50 era Olds
jd25q
January 31st, 2015 01:53 PM
