PDA
View Full Version : Other
Pages : [1] 2 3 4 5 6 7
  1. Kickdown cable connection to 1966, 4 barrel
  2. Gas tank vent
  3. 1968 Cutlass Convertible Quarter Window Regulator Question
  4. Help finding replacement clutch/pulley/bearing assembly for Four Seasons 58098 A/C
  5. speedometer
  6. 62 Cutlass Door mirror
  7. Vacuum storage tank for HVAC controls 75 Olds Cutlass
  8. running engine, wiring parking and tail lights
  9. Confirming defroster switch?
  10. Heater Control Valve vacuum connection -Where??
  11. 1970 442 A/C Question
  12. Rocker Panel Inspection, Cleaning, Rustproofing
  13. HVAC diagnosis chart contradiction?
  14. door window down stop bumpers?
  15. 69 Cutlass LH Mirror Help
  16. To jury rig or to convert: Tempmatic drama continued
  17. Power Windows
  18. 1966 Starfire rear window crease molding clip
  19. Tempmatic vacuum check relay repair options?
  20. Bushing for throttle cable
  21. Vacuum Actuators
  22. 79 Cutlass Electric Radio Antenna
  23. Quarter windows roller
  24. Steering column help...
  25. Plastic guide button on window
  26. Moser Black Friday Sale
  27. 66 headlight bezel nylon retainers
  28. New member
  29. Speedometer cable
  30. Changing bulb in lighted rear view mirror and best place to buy!
  31. Rebuild evap/vapor canister
  32. window felt
  33. Power window mechanism drawing
  34. AC drain location? 1970 442
  35. Window seals
  36. How does coolant in the old style recovery tank get back to the radiator?
  37. Tie Rod question for newby
  38. 1968 Olds 98 a/c restoration challenges
  39. 1966 Cutlass Cutlass AC compressor
  40. Tilt Column Question
  41. 63' Olds Dynamic 88 (locating starter with proper mount)
  42. Crossmember - modify or aftermarket
  43. Speed nuts
  44. Radiator hoses holding pressure.
  45. I need air pump brackets
  46. Fuel tank
  47. Oli Pump Drive Shaft
  48. 1971 442 fastback correct gas tank
  49. Alternate Valve Cover Gaskets
  50. EEVIR Rebuild on a 1975 - Should I just replace these valves?
  51. Need help accessing Convertible top pump 1971 442
  52. Summer Ventilation Operation
  53. Original 1957 371 fuel pump question
  54. 1970 350 Paint
  55. Turn signal issue
  56. 67 cutlass/442 fuel tank lines
  57. Added front Shoulder Belts to my 71 cutlass convertible
  58. 69 Cutlass S Holiday Coupe window seals
  59. POA Valve rebuild or ??
  60. 1993 Olds Ciera 3.3L + Speedometer issue
  61. Replacement AC Manifold Hoses for '75 98 Regency?
  62. 66 Cutlass AC
  63. REM sound deadener - how to apply?
  64. Radiator ID help
  65. 1962 cutlass engine fan shroud help
  66. 1966 Cutlass power steering hoses
  67. Color of Wiper Motor Bracket
  68. Blower motor Gasket
  69. Power steering pump bracket
  70. Looking for window seals
  71. Alternator bracket mounting
  72. OEM Finish, 66 442 Hood Latch Mechanism
  73. OEM finish on a POA valve?
  74. Any one know any good rubber rejuvenators?
  75. 1972 Cutlass heater core
  76. Engine Bay odds & ends
  77. Trip odometer reset button not resetting
  78. Reproduction cruise control rods?
  79. Heater core won't come out 76 cutlass w/ A/C
  80. 1970 Holliday LH rear quarter window guide
  81. 84 Cutlass Cruise Control - not connected to system
  82. I inherited my dad's 79 after he passed a few days ago, and I have some questions
  83. Evaporator drain, 76 cutlass
  84. Roof trim
  85. 1970 cutlass supreme convertible air condition process,
  86. 67 Olds 98 telescoping steering column question
  87. 1985 Cutlass A/C Question
  88. Interior mirror cable
  89. 1992 Oldsmobile 88 Royale air system issues
  90. 1984 olds 98 fuel rating
  91. 76 Cutlass Evaporator Removal - How?
  92. Window channels on the door
  93. Electric Power Steering…
  94. OEM or Vintage
  95. Maybe dumb question but can this AC leak be fixed or need new compressor?
  96. Mounting a pass door mirror
  97. '61 Olds 98 Fuel Level Sender
  98. Compressor/Clutch Screams When Engaged
  99. Do the windows on a ‘70 Cutlass S fit on a ‘70 Cutlass Supreme?
  100. Need 413977 Fan Belt for '76 Salon w/350
  101. File this under "I knew that was going to happen..."
  102. Gas Tank needed 1965 Olds Dynamic 88 convertible
  103. Custom Stickers - various
  104. How to separate the pieces of a 1972 bumper jack?
  105. 75 Cutlass Rad Lower Air Deflector Missing or Not
  106. Door hinge spring
  107. Trunk and door rubber bumpers install trick?
  108. AC Repair Sanity Check
  109. Window felt screws
  110. 70 Cutlass trunk light
  111. HVAC control unit vacuum
  112. Fuel Lines
  113. 1970 cutlass a/c
  114. A/C compressor problem - OK to drive?
  115. 61 Olds - What Takes Priority?
  116. Bumper holes
  117. 1970 Cutlass 455 AC gets hot on interstate
  118. Vacuum Actuators
  119. Ac Problems
  120. 1979 Delco AM/FM Cassette - motor speed adjustment
  121. Need help confirming - 68 442 exhaust manifolds
  122. 72 Cutlass Console Lock
  123. Chrome company suggestions
  124. Early W30 OAI Air Cleaner ducts alternative
  125. 1972 Cutlass fan clutch --replacement
  126. Fuel line patch/replace
  127. Headllight Bucket replace-remove stone shield ?
  128. '75 Oldsmobile 98 Climate Control Questions
  129. Fuel hose identification
  130. 1970 cutlass convertible top adjustment needed how
  131. 70 washer pump diagnosis help
  132. 64 Build sheet Locations
  133. Anyone got a Curtis key cutter and code decoder ring for GM keys?
  134. Dash cluster restoration Vacuum Orna-Metal
  135. need glue for top
  136. Convertible top
  137. 75 Cutlass - Fuel Tank Rubber Gas Lines Sizes
  138. Olds rocket parts
  139. AC delete panel
  140. Window adj?
  141. 1970 OLds Vista Cruiser Wagon: install door window
  142. Exhaust head pipe replacement
  143. Windshield wiper repair
  144. 80-85 Delta 88 Group
  145. Rate my old gas
  146. ID this mystery part
  147. 1965 F-85 Mirrors
  148. A/C tech question
  149. Heater inlet diaphragm
  150. 1971 cutlass supreme drivers fender emblem
  151. Not enough Fuel lines .
  152. Variable Displacement Compressor
  153. Antenna in window
  154. Hvac Heat 1970 Olds 98
  155. GM HEI for Oldsmobile
  156. PSA - Electronic Ignition conversion kits
  157. Neef advice of total amount of AC oil 1979 Cutlass
  158. 1988 Custom Cruiser HVAC temp control
  159. Door Locks Not Working
  160. fuel fiter
  161. 84 cutlass Fuel Lines
  162. Ever See a Car Radio with the Numbers Reversed ?
  163. Single speed wiper “crank arm” selection help
  164. Rebuilding the AC in my '75 98, need some external input...
  165. A Body Arlington General Motors Plant - 1972
  166. 1967 442 - aftermarket coolant overflow tank?
  167. Check your control arm bushing bolts
  168. I am in 394 helll
  169. Convertible motor/pump leak even after replacing with new
  170. OAI Air Cleaner Top - Is it Authentic or Aftermarket???
  171. Sourcing hydraulics for convertible top
  172. New-old radio fun
  173. 1969 vacuum door lock hose routing behind dash
  174. Headlight buckets n alphabet soup
  175. AC System 442 1971 - Accumulator/Dryer
  176. Help me get my seat belts out
  177. Evap connections
  178. Best door wx strip
  179. AC Compressor Change
  180. A6 AC Compressor
  181. How to adjust high idle? ‘69 Toronado
  182. Top stuck down
  183. 72 cutlass supreme with tilt, loose steerig column?
  184. Driverside, remote mirror, location
  185. Weather strip issue
  186. What to do about broken HVAC vacuum door actuator
  187. Rear noise (e.g. potholes)
  188. Brake line clearance for headers.
  189. Window felt.
  190. Help ID 67 Air cleaner - open element?
  191. ID Help Exterior trim
  192. Few questions about my car
  193. Vacuum or Throttle part
  194. Fuel System Problem - drainback
  195. Help ID power steering pumps 66-67, 68-69
  196. Help ID Trico wiper arms 64-67?
  197. Conv top issue - 72 Cutlass
  198. Fan Shroud
  199. Help ID convertible top frames - 1966-67?
  200. Fan shroud ID
  201. Spectra vs Aeromotive
  202. Looking for torque wrench recommendations.
  203. Fan Shroud
  204. A/C Vacuum canister ball style.
  205. 1966 cutlass vacuum actuator
  206. fuel tank
  207. gas tank vent
  208. OLD Video - HP TV 69 Cutlass Freshen Up
  209. Convertible top line up question
  210. 1971 Cutlass S anyone know what this part is called?
  211. AC hoses on 1987 Delta 88
  212. 72 Cutlass S 23 Years Sittiing - 1 Start & Drive Home ... & Paint Revival
  213. 1964 Cutlass bumper jack placement
  214. 1955 Super 88 sunvisor mounting
  215. 1964 Oldsmobile cutlass f85 power steering
  216. Upper ventilation inlet valve
  217. Alternative Window Replacements
  218. Quarter window replacement
  219. AC Evaperator Oil Return Line- 69 Hurst
  220. Is this an original ‘69 AC drier
  221. A/c compressor
  222. Freeze 12 Dispensing valve(Freon)
  223. Bringing AC back to life
  224. 1988 Custom Cruiser AC fan
  225. Glove box lock mechanism
  226. 1969 Dodge Super Bee A12 vs 1970 Oldsmobile F85 W 31 | STOCK DRAG RACE
  227. When pumping gas…..
  228. A pillar weather strip replacement.
  229. Column shifter
  230. 1972 Cutlass Console/Shifter
  231. Wheel Well Opening Trim Question
  232. Rear window trim - what adhesive to use?
  233. Glass scratches
  234. Survivor 1968 Oldsmobile 4-4-2 Test Drive!
  235. Sanden 508 on an Olds 350
  236. A/C recharging
  237. FIRST LOOK - 1970 Oldsmobile 442 Custom Convertible - BARRETT-JACKSON 2022 LAS VEGAS
  238. 1968 young - mobile commercials cutlass delta 88 olds 98
  239. 1967 Oldsmobile 442 W30 & 1968 Hurst/Olds - Design Walkaround
  240. Body mounts
  241. Legendary GMs - Oldsmobile, Pontiac, Buick | The Ultimate Compilation
  242. Radiator Hoses
  243. ‘68 442 Hood Question
  244. 68 cutlass flywheel/starter
  245. DS TX member?
  246. 1983 Delta 88 heater box water leak
  247. '96 LSS, Driver door wont open from the outside, "sometimes"..
  248. 1972 Pontiac Firebird Trans Am vs 1968 Hurst Olds | STOCK DRAG RACE
  249. A/C Question
  250. Clock Delete 67 cutlass
