Changing bulb in lighted rear view mirror and best place to buy!
Old Oct 9, 2025 | 08:49 AM
OLE442's Avatar
How to remove the bulb from a lighted 1972 Cutlass rear view mirror. What is the part number and where to but the correct bulb.
Thank you, OLE442
Old Oct 12, 2025 | 08:32 AM
Blue442's Avatar
Remove the clear plastic piece in the center. You can then gently pinch the forward and aft sides where the clear plastic piece was to remove the switch and bulb piece. Be gentle because the plastic gets brittle with age and heat from the bulb. Once out you can remove and replace the bulb. I’d recommend cleaning the switch contacts with scotch brite and WD-40 before reassembly. I believe the light bulb is #563.
Old Oct 12, 2025 | 10:22 AM
The lens needs to be removed first, then remove the rest of the switch / bulb holder assembly.
This thread has a lot of good pictures:
https://classicoldsmobile.com/forums...-diyer-121945/
You can get the bulb from any auto parts store.
https://www.autozone.com/electrical-...61ll/16852_0_0
Old Oct 13, 2025 | 07:58 AM
OLE442's Avatar
Thanks to all for the info and links!!
OLE442
May 14, 2023 02:51 PM
JOHNNYOLDS442
Mar 28, 2023 06:27 PM
Bigmikey65
Sep 1, 2022 08:39 PM
72442455
Aug 20, 2019 04:31 AM
Bfg
Oct 17, 2015 07:49 AM
