When pumping gas…..
Old Aug 18, 2022 | 04:15 PM
NorthBay72supreme's Avatar
When pumping gas…..
It’s a pain when the license plate gets in the way when pumping gas. Has anyone MacGuyvered a solution?
Old Aug 18, 2022 | 04:27 PM
don71's Avatar
same but different
Take your gas cap and leverage it the area of the spring, between those two sheet metal ridges. It should hold your plate open.
1970cs's Avatar
Lansing built
I have always laid the gas cap or wedge it tank side down, at the pivot point at where the plate holder bolt RH side at the bumper. Worked when I drove these daily and works like a charm still on my 70 supreme.
Pat
Old Aug 18, 2022 | 05:06 PM
lshlsh2's Avatar
71 cutlass convertible
x3
Old Aug 18, 2022 | 05:33 PM
I've just never had a problem with this. It looks like your filler neck should extend out a little further maybe? Hard to tell, because the image doesn't give a real sense of depth.
Old Aug 18, 2022 | 05:48 PM
Not the original cap.....
Old Aug 18, 2022 | 08:03 PM
Yes, GM did back when these cars were designed:
https://classicoldsmobile.com/forums...eply&p=1437510
Not sure if you were aware that the gas cap fits into the grooves near the hinge of the license plate bracket to hold the plate open for fuel filler access. No need for the block of wood.
Old Aug 18, 2022 | 08:59 PM
They're usually held open by the gas pump nozzle.
Old Aug 18, 2022 | 09:06 PM
VI Cutty's Avatar
True...but using the cap to hold it open means you're less likely to drive away forgetting to replace the cap!
Old Aug 19, 2022 | 05:17 AM
If only Olds had let people know about this feature, like by putting it in the OWNER'S MANUAL...
Old Aug 19, 2022 | 06:39 AM
mattking's Avatar
I can't tell you that it will fit with no modification, but I have saved two or three license plate holders from 90's caprices. They snap down into place and stay open. My intention was to use one them on my cutlass, and one on my 55 truck to hide a trailer hitch. I haven't got around to it yet
edski
Dec 13, 2021 04:45 AM
jaunty75
Jun 2, 2021 04:56 AM
capstoneclub
May 23, 2014 08:01 PM
jchavis44
May 11, 2012 08:10 PM
Pfiffle
Apr 1, 2008 02:12 PM
