Mounting a pass door mirror
Old Aug 16, 2024 | 12:12 PM
philv1983's Avatar
Hey, so I recently purchased both mirrors, I know left mirror is self explanatory, but the right mirror I'll have to drill into the door. Has anyone done this before? is the inner door structure designed for it? I want it to look original, but a little afraid to drill through my door.lol any advice?
Old Aug 16, 2024 | 12:18 PM
Is this for the '72 Cutlass in your profile? If so, you not only need the holes, but a support plate so the screws don't pull out of the door skin sheet metal. I used a piece of 1/8" aluminum plate for the inside support.
Here's a post about installing a passenger side mirror.
https://classicoldsmobile.com/forums...1970-a-172144/
Old Aug 16, 2024 | 12:24 PM
redoldsman's Avatar
Proud Viet Nam Veteran
It is also a good idea to put a wide piece of masking tape over the area where your are drilling in the event you drill bit decides to scoot. Use a centerpunch to mark your holes.
Old Aug 16, 2024 | 12:25 PM
philv1983's Avatar
The mirrors I bought came with the gaskets and I believe the inner metal plate. I can't see how the plate goes into the mirror base, so it has to be for inside the door.
Old Aug 16, 2024 | 12:27 PM
philv1983's Avatar
Yeah I plan on doing that, I just don't want to put the mirror in the exact same place as the left and factory was offset or vise versa. I'm trying my best to do it correct, it's just nerve racking drilling into a perfect door.lol
Old Aug 16, 2024 | 12:31 PM
Here's another mirror mounting thread with pictures:
https://classicoldsmobile.com/forums...-screw-135118/
Old Aug 16, 2024 | 12:33 PM
philv1983's Avatar
Thanks ken.
Old Aug 16, 2024 | 02:31 PM
Sport mirrors or chrome mirrors? The mounting is different
Old Aug 16, 2024 | 07:15 PM
philv1983's Avatar
original chrome mirrors.
Old Aug 17, 2024 | 05:48 AM
So you need to replicate the "keyholes" that are factory-punched in the driver-side door. I just did this on my 69 Cutlass wagon. I made a template from the driver side holes, put masking tape down on the passenger side, and marked on the tape from the template. I used step drills to make the holes and an air saw to cut the short straight section. The two anchor bolts on the new mirror dropped right in. You tighten from the top using a small allen wrench through the holes. Remember that since you are turning from the small end of the bolt, turn counterclockwise to tighten. This took less time to do than it took to write this.
Old Aug 18, 2024 | 08:47 AM
philv1983's Avatar
Is there a reason why the holes are different sizes? And what are those 2 little holes for? Do I need to add those to pass side also?
Old Aug 18, 2024 | 08:58 AM
The two little holes are for the sport mirror brackets. Your chrome mirrors don't use them. The two different size holes are just to allow for manufacturing tolerances if the punch is slightly off.
Old Aug 18, 2024 | 09:01 AM
philv1983's Avatar
ok thanks Joe. I'm going to attempt to make a template. I hope I do it right.
Old Aug 18, 2024 | 10:01 AM
philv1983's Avatar
Ok, I hope I don't have to drill into another body part again. That was very stressful. Lol I think I did pretty well, looks like factory. What you guys think?
Old Aug 19, 2024 | 10:32 AM
All good in the hood. Make sure you can see out of it.
Chuxter
Body work
Jun 29, 2024 12:19 PM
t574513r
Apr 24, 2019 10:23 AM
jlrichcreek
Apr 2, 2019 08:38 AM
rmoths
Jul 1, 2012 11:24 AM
Oldsmaniac
Jun 8, 2011 07:01 PM
