1972 Cutlass fan clutch --replacement
Old Apr 14, 2024 | 08:33 PM
Jersey Chris's Avatar
Big Kid with the Cutlass
I have a 1972 Cutlass ( non-AC) that had a frame off 20 years ago.
Doubt the bad fan clutch I just pulled out was the original HD Thermal clutch.
FYI- the 350cu was "worked" ( big cam, bored & channeled, etc etc) so I want to make sure a put in another Heavy Duty clutch
( car also has a 3 row radiator that I am adding a shroud to.
Everyone in the Olds groups I am in says get a Hayden HD. I found 2 on RockAuto ( 2747 and the low profile 2947). I measured the one I pulled out, which matched up in depth with the low profile, but it looks nothing like it. The Hayden is clearly bigger in overall diameter, beefier?, However bolt pattern to water pump matches up. Look at pictures below.
Also, here is a link to the only HD clutch on the internet that looks like the one I just pull out; look at front and back. it's almost exact:
https://www.thepartsplaceinc.com/pro...diameter/64484
And here is a link to one I just got in from Jegs that looks a lot bigger than the old one ( even shaft is thicker)
https://www.jegs.com/i/Derale/259/22...g+Confirmation
old one on right; yeah I just noticed the shafts are different.
Old Apr 14, 2024 | 09:25 PM
4speed455's Avatar
I used the Hayden 2705 for my 70 Cutlass with 455. It looks pretty close and a lot cheaper then the one you found.
https://classicoldsmobile.com/forums...-455-a-157790/
Old Apr 14, 2024 | 11:45 PM
Was there a question somewhere?
I say bolt that fan clutch on and see how it performs.
Old Apr 15, 2024 | 05:20 PM
So you have the Hayden 2705 which is a Standard clutch and not a Heavy Duty like the ones in W-30's and it keep's the motor cool?
I've actually been looking to add a HD clutch as my car runs hot in traffic
Old Apr 15, 2024 | 05:44 PM
70sgeek's Avatar
'72 Cutlass ragtop
I use a 215046 (Carquest) standard duty - the 2 HD units you mentioned will also fit (be sure in any case to use the sleeve that they come with to ensure a proper fit onto the water pump stem
Old Apr 15, 2024 | 05:55 PM
Thank you
jpayne_80@hotmail.com
May 30, 2022 06:54 PM
tkcutlass
Mar 28, 2022 08:01 AM
jpc647
Dec 16, 2016 06:21 AM
Macadoo
Aug 17, 2014 05:09 PM
ztim
May 6, 2007 12:23 AM
